Intel® Network Adapter Driver for Windows® 10
Installation failed
Reason: "No Intel Network connection found on my system."
Yet, Intel Driver and Support Assistant keeps showing message
that there is one Update available to install or update.
Please advice as of how to get rid of above message.
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[If you find any Intel driver you might need, download and save it now.]
Hello AlHill,
Per your reply, you asked me to run a report, which I provided in my answer below this message.
Attachment name: Intel info.text
No one has answered as of what to do next. Since the issue is still present, I cannot mark it as an
accepted solution..
FYI: I tried running the update again, and received a system reply that the Network Adapter is not
available for my version of Windows 10, which is version 22H2.
That is okay for me. However, I still have that outstanding message "that the Network Adapter is
available as an update." How do I get rid of this?
Hope you get this. Thank you.
Edmundo
