- Contrassegnare come Nuovo
- Preferito
- Iscriversi
- Disattiva notifiche
- Iscriversi a feed RSS
- Evidenziare
- Stampare
- Segnalare contenuto inappropriato
I am using a MSI B450 Gaming Pro Carbon AC Board with integrated Intel I211 Ethernet Adapter. I like to remote start my pc in some cases. But unfortunately, i do not get the "extra" Intel Driver options after installing the latest intel ANS 23.5 driver Package with PROSet for Windows 10 in 64 Bit. I have Windows 10 Enterprice 1809 with the latest patches.
I See only the standard register cards in the device manager and adapter settings. But not the alterd, when the intel driver is installed. I attached a screenshot with the options i get, but not the one i normally get, when i install the intel drivers.
I hope you guys can help me out.
thanks
Link copiato
- « Precedente
- 1
- 2
- Successivo »
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hello Daniel,
thank you for your response. No before i had the same options as i have now. So nothing changed but the version number is higher. No more options. The reason why i have tried to update the driver, was to get this option. On my pretty old server system with an Intel(R) 82579LM Gigabit Adapter with an driver version 11.13.51.0, the option is available.
Before i Updated, i used a msi provided network driver. Furthermore I have tested the 23.5 Driver on my company pc with windows 7 and another company pc with windows 10 1803 (both with an Intel(R) I219-LM Adapter) with no issue and the needed option. So I think there must be an problem or bug with my specific setup (HW + OS). Please find attached the requested file.
Best regards
Christian
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hey Daniel,
did you get any new information?
Best regards
Christian
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hi Daniel,
could you collect new information regarding the issue?
Best regards
Christian
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hi Daniel,
strange when I start the PROset Adapter Configuration Utility, I got an error message, that my adapter is not supported? What's going wrong here?
Do you have an Idea? I have recreate a export Log with the system support utility and will attach it to a new post.
Best regards
Christian
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hi Daniel,
sorry for my late response. So I have reinstalled the driver two times. After the first time after some reboots the utility was broken again.
So what I could say is, that when I uninstall the proset software and reinstall it without rebooting, i can see the needed option in the utility software. But it's wired that only that option is shown in german language. On Powershell I can also see the option. in The Device Manager Adapter Settings, this option is not visible.
So i have enabled it and did some testing.
When I bring my pc into standby and send an wol paket via smartphone app to the nic mac address the pc resume from standby.
When I fully shutdown the pc and try to start the pc with the same wol paket via smartphone app nothing happens. So it seems that the enabled option did not work.
So I have no Idea, whats going wrong and I hope you can help me. I think my settings in os and bios are correct because the wake from standby is working just fine.
Here are Some screenshots.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Finally it's working.
So after I disabled the Fastboot in the powercfg Settings of Windows 10 its working.
Disable Fastboot
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Power
HiberbootEnabled DWORD
0 = Turn off fast startup
1 = Turn on fast startup
I need also to set the proper options on your BIOS: "Wake Up Event by: BIOS", "Resume by PCI/PCI-E Device: Enabled" and "ErP Ready: disabled"
Best regards
Christian
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hello Daniel,
yes this error is still alive :-(
Any suggestions to solve this issue?
Best regards
Christian
- Contrassegnare la discussione come nuova
- Contrassegnare la discussione come letta
- Sposta questo Discussione per l'utente corrente
- Preferito
- Iscriversi
- Pagina in versione di stampa
- « Precedente
- 1
- 2
- Successivo »
