Ethernet Products
5868 Discussions
Cannot build irdma-2.6.51 in Ubuntu 24.04
Derek64
When I use the ./build.sh script in the uncompressed irdma-2.6.51 archive, several functions are implicitly defined and the script will not complete:
I disabled the warning as error for these lines, but the linker could not find the associated functions. Do you have any recommendations for getting past this problem?
Thank you,
Derek
Fikri_Intel
Hi Derek64,
Thank you for contacting Intel.
We appreciate you reaching out to us regarding the reported issue. To assist you more effectively and provide an accurate solution, we kindly request the following details:
1- What system and network card model are you currently using?
2- Does the network card come with the system or purchased network card saperately?
3- Please elaborate more regarding the issue.
4- What troubleshooting has been done?
5- Have any changes been made prior to the issue happening?
Once we have this information, we will be able to guide you better and provide the appropriate support.
Fikri_Intel
Derek64
Thank you for your response:
I am using Ubuntu 24.04 LTS and an Intel E810-2CQDA2.
I purchased the network card separately.
I have a new installation of Ubuntu 24.04. I downloaded and installed the ice-2.5.4 driver, and then tried to install the irdma-2.6.51 driver. There are several warnings, which the compiler treats as errors
  • utils.c has "del_timer" and "del_timer_sync" declared implicitly
  • verbs.c has a pointer mismatch when initializing a struct ib_mr on line 4514
  • cm.c has an implicit declaration of "del_timer_sync"
These warnings prevent the build.sh from completing.
  • I disabled the warnings at the lines where they occur and completed the compilation. However, the link step failed, because the functions were not found.
  • I have reinstalled Ubuntu 24.04 cleanly and attempted the installation again.
After installing Ubuntu, I have updated the Nvidia graphics driver and the application software. I have installed the build-essential pack as well as the packs listed in the irdma README.
pujeeth
Hi Derek64,
Thank you for sharing the information, In order to proceed further we would request you to share us the SSU logs.
https://www.intel.com/content/www/us/en/support/articles/000008563/ethernet-products.html
Regards_Pujeeth
Derek64
Here is the result of the scan.
Thank you,
Derek
