Ethernet Products
5744 Discussions
D965WH / On-board GB ethernet - driver install causes PC to shut down
On a presumably unrelated note, my primary HDD's bootsector became corrupted and no amount of work would restore it...so a complete re-install of Windows XP was needed.
After the re-install was completed, I attempted to install the Intel-provided driver for my 82566dc on-board ethernet controller...except that when the driver install reaches a certain file (e1000-something.dll), the PC shuts down. Every time, without fail.
I was able to install other drivers for other hardware without issues. I've updated the board's BIOS, too. The only time the PC shuts down automatically is when I attempt to install this driver.
Any ideas?
What's your source for the driver? If it's not on a CD, you may need to redownload to verify its integrity.
Also, you mentioned the bootsector was corrupted. Did you reformat the drive completely?
I honestly have no "real" suggestions for you, so I just thought I'd cover some basics.
The drivers were downloaded from intel.com, and I've tried on two different internal HDDs...
No one I've talked to at work in our IT department has any idea, either. At this point I may just try a stand-alone NIC to see if I can at least get online, patch up the OS, install the latest motherboard drivers, etc. and then try to get the onboard NIC working again.
I have the same issue. I have a D965WH Board, I'm using it as a File Server. I just shut it down last night to install new HDDs and it would shut my PC down during Windows Boot. So I installed a fresh copy of the OS on another Drive, and as soon as it is about to finish installing the OnBoard NIC GB Driver it would Turn Off / cause my PC to instantly shut off. I have tried updating the BIOS, I'm using the lastest drivers, nothing. Any Ideas? Were you able to figure out what was worng with yours, my issue may be very similar. My guess is the OnBoard NIC went bad.
-Alka
