Ethernet Products
5719 Discussions
DP55WB network problems
the computer freezes on high network trafic > 100 mbit, i updated to the latest bios, everything else work fine.
JPisz
New Contributor II
Pull down the latest version of the Intel network drivers from intel.com.
This may be related to the known issue in DP55KG boards (where the NIC only negotiates at 100mbps) and probably also affects the DP55WB motherboard similarly.
Try upgrading the driver first.
Justin.
JPisz
New Contributor II
Correction (in Linux): negotiates at 10mbps.
JPisz
New Contributor II
