The background:
I'm using the 82588EB SR-IOV function, and attach the VF direct to the VM. My app running inside the VM requires send and receive both VLAN tagged and untagged traffic, just like the VLAN trunk port on the switcher, and may require 4096 VLAN tags pre VF. The traffic will be tagged inside the VM by the app itself.
My questions are:
What kind of configuration should I do for the NIC or VF to achieve my goal?
Should the promisc mode be disabled?
Does it related with the VLAN filter parameter?
And does the hardware or driver has any limitation for the VF's allowed VLAN tagged/untagged traffic?
Before I asked the question, by searching the community, I saw some topic about VLAN filter, and seems there is limitation about supported VLAN tag number, 64 or 256 or 512, anyway, not all 4096 VLAN tags are allowed to pass to the VM.
If the limitation is true, I would like to know why, is it the hardware limitation or driver limitation?
- Tags:
- GiLAN
Hi Henry_Wang,
Thank you for the post. You may refer to this SR-IOV user guide for the implementation information:
http://www.intel.com/content/www/us/en/embedded/products/networking/82599-sr-iov-driver-companion-guide.html
I will also further check.
rgds,
wb
Hi Henry_Wang,
Good day. Please refer to the data sheet for more information, you may refer to the section
1.4.7.1 PCI- IOV and 1.4.7.2 Packet Filtering and Replication at
http://www.intel.co.uk/content/dam/www/public/us/en/documents/datasheets/82599-10-gbe-controller-datasheet.pdf
As per datasheet VLAN ID is between 1 and 4094. Zero means no VLAN tag support
rgds,
wb
Hi Henry_Wang,
Good day. Just want to follow up if you still have further inquiries?
wb
