We are looking at FM10420 controller based NICs. Does this controller support timestamping of only IEEE 1588 frames or every frame? Where can I find a datasheet for this controller?
- Tags:
- Memory
Hi vj535in,
Thank you for the post. I am not an expert on this ethernet controller but I found on our ark.intel.com, the specs show the controller support IEEE 1588.
http://ark.intel.com/products/92674/Intel-Ethernet-Multi-host-Controller-FM10420 Intel® Ethernet Multi-host Controller FM10420 Specifications
Hope this helps.
rgds,
wb
Hi wb,
Thanks for the response. I found the same specs but we are interested in the detailed datasheet. Fo example, the link below is the datasheet for XL710 controller
http://www.intel.com/content/www/us/en/embedded/products/networking/xl710-10-40-controller-datasheet... Intel® Ethernet Controller XL710 Datasheet
We need the same info for FM10420.
Vijay
Hi vj,
Datasheet for FM10420 can be found at http://www.intel.com/content/www/us/en/embedded/products/networking/ethernet-multi-host-controller-f... Intel® Ethernet Multi-host Controller FM 10000 Family: Datasheet
A linux version of the fm10k driver can be found on sourceforge at https://sourceforge.net/projects/e1000/files/fm10k%20stable/0.19.3/ Intel Ethernet Drivers and Utilities - Browse /fm10k stable/0.19.3 at SourceForge.net , or 3'd party websites for newer version ( fm10k-0.20.1.tar.gz )
