Ethernet Products
5741 Discussions
Does the E810-XXV support Fiber Optics?
sbd27
We purchased a new Dell R750 and it came with a E810-XXV nic with a M14MK Optic. I cannot get a link on our Cisco Nexus 9300 switch, however, when I installed an old XX710 I get a link. The Intel website shows the media type as Copper, and my iDRAC shows it as Twisted Pair. I can't seem to get a definitive answer anywhere.
LeXuanTinh
Hi There
Below this solution for you
1. Set speed port switch and server manual to 25G
2. set port network on the server
+  Link FEC change to CL74
+  Auto-negotiantion --> disable
3. double check and set port on switch
+ Link FEC change to CL74  ( FC-FEC (CL74) )
follow the link for sw setting : https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/kb/b_Cisco_ACI_and_Forward_Error_Correction.html
sbd27
Thanks Again, but I still would like Intel to respond to this thread. I noticed on your original claim that you got a connection with a DAC cable. I'm still concerned that the E810-XXV does not support Fiber-Optics. The same M14MK Optic I run in my XX710 nics show up in my Dell iDRAC as "Fiber Optic", but in the  E810-XXV it shows up as "Twisted Pair". I'm going to open a ticket with Dell too.
Also, when you look at the specs from Intel's site:
https://www.intel.com/content/www/us/en/products/sku/189760/intel-ethernet-network-adapter-e810xxvda2/specifications.html
It says the medium type is "Copper". We are about to purchase 8 servers with 3 of these cards in each server, I need to know if this is the right card.
sbd27
OK, this problem is resolved, but I do not want to mark the issue has a solution.
Unlike LeXuanTinh issue, we had to set the FEC mode to FC-IEEE.
Again, I would like Intel to explain why LeXuanTinh had to set his switch to FC-FEC, the documentation Intel provides for the card says if you are using speeds over 10G you need to set the FEC to RS-FEC, but we had to use FC-IEEE?
Thanks!
Achilles_Intel
Hello sbd27,
We are sorry to hear about this issue you had to encounter with your adapter. Before we could check this with our engineers, we hope you don't mind if we ask for a photo of the E810-XXV adapter you used so we could validate as well.
Let us know if you have additional questions or need clarifications. We will reach out after 3 business days should we not receive an update from you.
Thank you and have a nice day.
Achilles M.
Intel Customer Support
Achilles_Intel
Hello sbd27,
Good day.
We are following up on the information we are requesting for this thread. We were asking for the rear and front photo of the adapter so we can further validate it.
Let us know if you have further questions or need clarifications. We will reach out again after 3 business days if we do not receive a response from you.
Achilles M.
Achilles_Intel
Hello sbd27,
Good day.
We are following up on your inquiry for this thread. Since we haven't heard from you in a few days, this thread will now be closed. Feel free to post a new question in the forum if you have additional inquiries as this thread will no longer be monitored.
Achilles M.
