hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
Ethernet Products
5352 Discussions
Duplex Settings
Is there a way to determine the duplex settings from the registry. I am trying to write a script to pull the duplex settings from multiple PC's (over 200) and I don't want to manually check each one. I can check the network switch for the info but I need to get it from the PC. Any suggestions.
