Ethernet Products
5736 Discussions
E810 loosing latency function vs xxv710 on 4x bus?
Opcod34
Hi
 I would like some precision on the network card E810XXVDA2 that can be used on linux system, debian. It will be to use the card on pci3 x4 only. Like, in order to get the new feature of the DDP protocol acelleration and rocev2 : It need to be 2x E810 facing or What will it be for a E810 facing a xxv710 ?
As well, what is the Nvme rdma speed boost.. there's not much real world info... as in doing a test it help to copy faster or so .. ?
And based on a pci3 x4, is the low latency feature of the e810 serie just get negated by the pci bus speed ... this making a better choice to get xxv710 instead ? Or still, the e810 could provide better work load among cpu core ...    For 25 - 25g situation  and 25-10g situation.
Caguicla_Intel
Hello Opcod34,
We will be glad to assist you on your request but first, we hope you don't mind providing information below for us to better understand it.
1. Do you wish to purchase E810XXVDA2 or XXV710 and know which card is better? If no, do you have the cards already and you are currently doing some tests regarding the performance of both cards?
2. Can you share more information regarding your query or intended configuration?
3. What are your requirements on your setup or features that you wish to use?
We will follow up after 3 business days in case we don't hear from you.
Crisselle C.
Intel® Customer Support
Opcod34
The setup will be mostly point to point for like 4 unit connected all together in kind of a ring.  pc1: port 1out to port 2 of pc2 .. All on da2 card. All pc only get available 1 slot pci-e3 4x electric. All to be used in virtualization proxmox/esxi and perhaps using the nPar function on half.
 As on real world speed bench, it can be nice if you have some as it will be mostly to transfert/decompress file like over nfs and live backup. No vlan stuff used.
I was about to received a first xxv710 and would like more info on the feature of the 810 before getting other. As if i transfert like : mswindows.iso from vm#1 on pc1  -to  pc3 in vm#6 .. is any used of thoses diff feature ?
 *on nPar, is both give only static bw assignation or it's possible to have it also in auto mode ? As port 1 bw set pf3=10g , pf4=10g .. but will auto adjust to like 22g on pf3 if higher speed is required ..
Caguicla_Intel
Hello Opcod34,
Thank you for the reply.
The performance would depend on multiple factors. This includes the Operating System, hardware, cables, adapters used etc. What we can do for you is share documentations regarding our cards for more information.
Here is the Product Specifications of Intel® Ethernet Network Adapter XXV710-DA2
https://ark.intel.com/content/www/us/en/ark/products/95260/intel-ethernet-network-adapter-xxv710da2.html
Product Brief for detailed information regarding the adapter
https://cdrdv2.intel.com/v1/dl/getContent/641688
Intel® Ethernet Network Adapter E810-XXVDA2
https://ark.intel.com/content/www/us/en/ark/products/189760/intel-ethernet-network-adapter-e810xxvda2.html
https://cdrdv2.intel.com/v1/dl/getContent/641674
If you will be using these 2 adapters, please expect differences as these are form 2 different families.
We are also sharing link below for Tuning Throughput Performance for Intel® Ethernet Adapters
https://www.intel.com/content/www/us/en/support/articles/000005811/ethernet-products.html
Please also ensure that you will be using validated Operating system as well as hardware on your setup to achieve the expected throughput of the cards.
Sharing with you the list of Supported Operating Systems for Retail Intel® Ethernet Adapters
https://www.intel.com/content/www/us/en/support/articles/000025890/ethernet-products.html
Feel free to let us know if you have questions/clarifications.
Should there be no response, we will follow up after 3 business days.
Crisselle C.
Caguicla_Intel
Hello Opcod34,
Good day!
This is just a follow up to check if you read our previous reply. If yes, please confirm and let us know if you have additional questions or clarifications needed on this matter so we can assist you further.
Awaiting to your response.
Crisselle C.
Intel Customer Support
Caguicla_Intel
Hello Opcod34,
I hope you're doing good!
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
Thank you for choosing Intel and stay safe!
Crisselle C.
