Ethernet Products
5732 讨论
E810 statistics not being propagated to Linux kernel /proc/net/dev
0x4A6F686E
初学者
868 次查看
New attempt as I wasn't fast enough responding to the previous question.
we're running a Debian Trixie server with kernel version 6.12.48+deb13-amd64.
This server has an Intel E810-CQDA2 card and we compiled the latest ice driver from Intel.
The HPE server has the latest firmware from HPE installed.
$ ethtool -i ethX
driver: ice
version: 2.3.10
firmware-version: 4.80 0x80020543 1.3805.0
Normally we request NIC statistics using the ip-command, by looking at /proc/net/dev and by using ethtool,.
However, for this E810 card/driver, it turns out that the counters in /proc/net/dev are only updated after we run statistics gathering using ethtool -S. Otherwise they stay the same until another run of ethtool -S.
We also have multiple systems with X710 cards, with the i40e driver. On those systems the counters in /proc/net/dev are updated automatically. This problem does not occur on those systems (same OS, same kernel, same server hardware, only another NIC).
I've read the documentation in the driver sources but didn't find any clue as to why this happens.
Is there any way to tell the driver to keep the counters in /proc/net/dev up to date because other tooling like atop uses /proc/net/dev as its source for statistics gathering?
As for the previous questions:
Linux distribution:
$ cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 13 (trixie)"
NAME="Debian GNU/Linux"
VERSION_ID="13"
VERSION="13 (trixie)"
VERSION_CODENAME=trixie
DEBIAN_VERSION_FULL=13.1
We are not using SR-IOV. As for DDP:
The DDP package was successfully loaded: ICE COMMS Package version 1.3.46.0
This behaviour is present on multiple systems and within 1 system on multiple NICs
We have tested with a previous version of the driver, v2.2.9.
Attached is the output of the following commands:
1) while sleep10; do ethtool -S <interface> ; done # running in the background; output was not captured
2) while sleep 1; do date; cat /proc/net/dev; done
You can see in that output that the /proc/net/dev counters are updated once every 10 seconds. If we adjust the interval of the ethtool -S loop, the update frequency changes accordingly.
Any ideas how to fix this? Is it a driver issue or a Linux kernel issue?
Kind regards,
John
0 项奖励
10 回复数
Sazirah
员工
823 次查看
0 项奖励
0x4A6F686E
初学者
801 次查看
Hello  Sazirah,
we just upgraded to the recommended versions but unfortunately the problem still exists.
Current situation:
$ uname -r
6.12.48+deb13-amd64
$ ethtool -i ens1f0np0
driver: ice
version: 2.3.14
firmware-version: 4.90 0x80020ef2 1.3863.0
We used the DDP package provided; see this message in dmesg:
ice 0000:11:00.0: The DDP package was successfully loaded: ICE OS Default Package version 1.3.50.0
and also this one:
ice 0000:11:00.0: fw 7.9.1 api 1.7.11 nvm 4.90 0x80020ef2 1.3863.0 [8086:1592] [8086:0002]
Any other suggestions?
Kind regards,
John
0 项奖励
TejasMohan
员工
794 次查看
Hello 0x4A6F686E,
Greetings from Intel!
Thank you for writing back.
We have reviewed your environment and noticed that you are using Debian Trixie on this server.
Based on our documentation for supported operating systems for the Intel® E810-CQDA2 adapter below
https://www.intel.com/content/www/us/en/content-details/630155/intel-ethernet-controller-e810-feature-support-matrix.html?wapkw=E810-CQDA2%20product%20support%20matrix&DocID=630155
the card has been validated for Linux: Debian 11.
Could you kindly confirm the OS version to check further.
Tejas
0 项奖励
0x4A6F686E
初学者
762 次查看
Hello Tejas,
yes indeed, we are using Debian version 13 and no, we cannot downgrade to the old Debian version 11.
So, we are on our own? Are can we expect Debian 13 with Linux kernel 6.12 being supported in the near future?
Kind regards,
John
0 项奖励
MACM
员工
753 次查看
Hi 0x4A6F686E,
Greetings of the day.
Hope you are doing great.
Thank you for your response.
If any developments occur concerning Debian 13 in future, you will be notified.
Mohammed Ali CM
0 项奖励
Sazirah
员工
633 次查看
Hi 0x4A6F686E,
Good day,
This is related to your enquiries above, I would like to check if the issue has resolved?
If you have any questions or clarifications, please let me know.
Sazzy_Intel
0 项奖励
0x4A6F686E
初学者
551 次查看
Dear Sazirah,
unfortunately the issue still exists, even with the latest ice driver and DDP package.
Kind regards, John
0 项奖励
Poojitha
员工
519 次查看
Hi 0x4A6F686E,
Thank you for your response. We kindly request you to allow us sometime to check the details and provide you with an update.
Poojitha N
0 项奖励
Sachinks
员工
311 次查看
Hello 0x4A6F686E,
Greetings!
We have checked this further with our team and we did not find any specific elements in the driver code base that could explain the behavior you are observing.
As Debian 13 is not in our tested list of OS and as you have mentioned that you cannot downgrade to Debian 11, would you be able to try with any of the other supported Linux OS?
You can check the supported OS list in the below link :
If possible, kindly try with any of the other supported Linux OS and let us know the outcome.
Please don’t hesitate to contact us for any further assistance.
Thank you for using Intel products and services.
Sachin KS
0 项奖励
Sazirah
员工
109 次查看
Hi 0x4A6F686E,
Good day,
Sazzy_Intel
0 项奖励
回复
