Ethernet Products
5705 Discussions
Este dispositivo não pode ser iniciado. (Código 10)
_Alanderson
A internet do meu computador não está funcionando no Windows 10, as vezes tenho que atualizar o drive de rede, mas nem sempre funciona...
Intel(R) Core (TM) i3 CPU 550 @ 3.20GHz
8,00 GB RAM
HD 464GB
Número da série: 1A285FC39
Intel(R) 82578DC Gigabit Network Connection
Alguém poderia me ajudar nesse caso?
n_scott_pearson
We need more information than you have provided.
Please download and run the Intel System Support Utility for Windows. Select Everything and then click on Scan. Once it completes the scan process, click on Next and then Save. Pick a name for the text file to produce and click on Save to create it. You can then close the app. Finally, open a response post and then, using the Drag and drop here or browse files to attach dialog (below the edit box for the body of your response post), upload and attach this text file to the response post.
_Alanderson
Não tenho como baixar, a internet não funciona por causa desse erro...
OBS:*
Consegui transferir de um computador pra ele e fazer os passos a passos que você falou.
n_scott_pearson
The only drivers for this controller would seem to be in the (large!) Admin package. Here is link for download page: https://www.intel.com/content/www/us/en/download/2593/administrative-tools-for-intel-network-adapters.html.
If the main executable (autorun.exe) for the package does not support the installation of this driver (since it was originally intended for Windows 8), you can attempt to install it manually. Traverse to subfolder PRO1000\Winx64\NDIS63, right-click on file e1k63x64.inf and select Install from the context menu displayed.
Hope this helps,
_Alanderson
Opa, boa noite. Nenhuma dessas informações funcionaram... E não achei essa subpasta para instalar manualmente. Você recomendaria outro processo?
