- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
In the last few driver updates (28.3 and 29.0) the Network Adapter Driver for Microsoft Windows 11 has dropped the I225-V from supported adapters (no longer listed in release notes, and the installer states that the hardware does not have a supported Intel Ethernet adapter).
The Ethernet Adapter Complete Driver Pack continues to include the drivers for the I225-V, at least for manual updates from Windows Device Manager.
Is this by design or by accident as it implies that the I225-V has stopped having any updates, which is concerning for those of us with the large number of motherboards which use the I225-V.
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello AndyMac60,
Thank you for posting in Intel community forum.
We will check the details and get back with an update shortly.
Sreelakshmi
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello AndyMac60,
Kindly help us with the below details to proceed further.
-Complete Ethernet model.
-System information that you are using.
-Confirm if the ethernet controller is embedded with the motherboard.
Sreelakshmi
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Network adapter is I225-V (there are two on the motherboard, one is currently disabled)
Asus ROG STRIX Z590-E
Ethernet is embedded on motherboard
Note that the Windows 11 driver install worked up until 28.2.1 (from memory). It started stating it did not recognise it from 28.3 onwards --- and the ALL download includes the driver which can be checked/updated from Device Manager.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello AndyMac60,
Good day!
Thank you for the confirmation. Since you purchased an OEM branded mainboard- Asus ROG STRIX Z590-E and the Network adapter is I225-V is embedded in the mainboard, we suggest you contact OEM (ASUS) for resolving the issue that you were facing. Using SW and FW versions that have not been validated to work together will affect performance, feature availability, and system stability.
Their expertise and resources may be instrumental in resolving the issue and ensuring the proper functioning of the Network adapter is I225-V on Asus ROG STRIX Z590-E.
Please don't hesitate to ask any further questions in the future. Feel free to start a new conversation, as this thread will no longer be monitored.
Thank you for understanding.
Sreelakshmi
