Ethernet Products
5821 Discussions
Ethernet Testing - Pattern generator (Windows 10 IOT enterprises - Intel® Celeron® N3350 (2 x 1.1 G)
RAJESH_HCL2021
Hi Team
                   We using Congatec SOM (Intel® Celeron® N3350 (2 x 1.1 GHz, 2 MB L2 cache, 6W)) for our Project, We planned to do Ethernet Compliance Testing 100Base-TX & 10Base-T,
we need support to Generate below Patterns
1.Link Pulse
2.Pseudo-random sequence
3.All 1s or 0s
4.Scrambled idles
10Base-T
Test Name Pattern Name
Link Pulse Link Pulse
MAU Pseudo-random sequence
TP_IDL Pseudo-random sequence
Jitter Pseudo-random sequence
Differential Voltage Pseudo-random sequence
Harmonic All 1s or 0s
Return Loss Pseudo-random sequence
CM Voltage Pseudo-random sequence
100Base-TX
Template Scrambled idles
Differential Output Voltage Scrambled idles
Signal Amplitude Symmetry Scrambled idles
Rise Time Scrambled idles
Fall Time Scrambled idles
Rise/Fall Time Symmetry Scrambled idles
Waveform Overshoot Scrambled idles
Jitter Scrambled idles
Duty Cycle Distortion Scrambled idles or 0101 pattern
Return Loss Scrambled idles
When we using a Ethernet Analyzer suggested below
If you are using a traffic generator to generate the signal, set the traffic generator to generate the signal pattern as listed in the table.
If you are not using a traffic generator to generate the signal, contact your PHY vendor for a special program to generate these patterns.
We can't Find Traffic Generator , Kindly assist us for getting  Traffic Generator or suggest a way(register setting or any) to Generate these Patterns for our Ethernet Testing for 100Base-TX & 10Base-T for Below mentioned Inter Processor in Windows 10 IOT Enterprises OS
Processor : Intel® Celeron® N3350 (2 x 1.1 GHz, 2 MB L2 cache, 6W)
Ethernet Controller : 2x Intel® I210 (Industrial) / I211 (Commercial) Gigabit Ethernet Controller with SDP support | 2x real-time trigger
R.Rajesh
+919566063348
Mike_Intel
Hello RAJESH_HCL2021,
Base on your post, let me check, are you designing a system with embedded Intel Ethernet card?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel® Customer Support
Mike_Intel
I hope you are having a good day. I just want to make a follow up on the information that I asked for me to assist you.
Michael L.
Mike_Intel
I am just sending another follow up on the information that I requested.
If you need further assistance, please post a new question.
Thank you.
Michael L.
