Ethernet Products
5530 Discussions
Ethernet internal Loopback - Driver Source/ API
avr
Hi All,
I have a windows 10/intel i7 based product.
There are 3 ethernet ports in the system based on intel I210 ethernet controller.
The I210 supports the following types of internal loopback in the LAN interface: • MAC Loopback (Point 1) • PHY Loopback (Point 2) • SerDes, SGMII or 1000BASE-KX Loopback (Point 3) • External PHY Loopback (Point 4).
I wanted to make custom built in test in application space which will do the available hardware loopback. So my question is whether is there any Windows API from driver is available to do the same or is there any option to modify the windows driver and do the same?.
Thanks in advance
Abhilash VR
Mike_Intel
Hello avr,
For us to further assist you,kindly provide the he windows operating system that you intended to build the application.
If you have questions, please let us know.
Michael L.
Intel Customer Support Technicians
A Contingent Worker at Intel
avr
Thank you Michael !
I am using windows 10 professional (ver 1903)
Abhilash VR
Mike_Intel
Hello avr,
Thank you for the quick response. Let me further check this and get back you.
Please give me 2 to 3 working days to further check this.
Michael L.
Mike_Intel
Hello avr,
I sent a PM. Please check your inbox.
Michael L.
avr
Thank you Michael, I responsded to your message. Please check and let me know if you need any additional input from my side
Abhilash V R
Mike_Intel
Hello avr,
To create Customer Non-Disclosure Agreement, please follow the steps below:
1. Go to the link below then, select "CNDA" under “Initiate Pre-signed, Standard Form Agreements”.
2. Tick the “CNDA Verification” and fill out all the required fields then click, "Submit Request".
Note that once submitted, the pre-signed CNDA will be emailed to the customer for eSignature.
https://intel.tap.thinksmart.com/prod/Portal/WorkflowDashboard
Michael L.
avr
Thank you Michael, But the link you provided is not working.
I am getting "This site can’t be reached" (sifederation.intel.com’s server IP address could not be found.) error. Please find the screenshot
Abhilash VR
Mike_Intel
Hello avr,
Can you try to access the link using a different system or from a different network?
The link is working fine here:
Michael L.
avr
Michael, I tried the same from my mobile and my office computer.Now again i tried from another network,its not working.
The above link is redirecting to sifederation.intel.com ..... For me it looks like an internal link
Can you please check and advise
Abhilash VR
Mike_Intel
Hello avr,
Can you try to this link instead?
 https://e2esm.intel.com/navpage.do
Michael L.
avr
Same problem,attaching the screenshot
Mike_Intel
Hello avr,
The links that I provided are working fine here on our end. Kindly check your settings and try again.
Michael L.
Mike_Intel
Hello avr,
I just want to make a follow up if you were able to gather the details that we need to proceed with this case.
Michael L.
Mike_Intel
Hello avr,
I am just sending another follow up on the information that I requested.
Since we have not heard back from you, I will close this inquiry now.
Michael L.
avr
Dear Michael ,
Sorry for late reply,I was away due to personal work.
I tried the links from my office,my personal phone, and my collegue tried from USA using his personal network. In all atttempt it was showing
Can you please sent me offiline version of the same , so I can sign and send the same
Abhilash VR
Mike_Intel
Hello avr,
You need to acquire the CNDA online, we don't have offline version of this.
And link is working fine here on our end:
Michael L.
avr
I think this is an internal link, It is redirecting to following address,and am not able to acess
https://sifederation.intel.com/federation/Contract_Automation.asp?RelayState=3d49c86c56ca5a8f783ea2c83a7e4eb7
Abhilash VR
Mike_Intel
Hello avr,
You may try to create an account. You need to create a profile/account.
Michael L.
Mike_Intel
Hello avr,
I just want to check if you were able to obtain an NDA.
Michael L.
Caguicla_Intel
Hello Abhilash VR,
Good day!
Please be informed that we will now proceed in closing this request since we haven't received any response from our previous follow up. Should you have any other assistance needed from Intel Ethernet team, feel free to post a new question.
Crisselle C
