Ethernet Products
5661 Diskussionen
Flashed i226-V firmware on i225-V, rollback mode does not work
NRGSupport
Einsteiger
1.168Aufrufe
I copied an existing nvmupdate.cfg file and forgot to replace the device id 1573 (i225-V) with 125c (i226-V). When I ran nvmupdate64e.efi by accident on a system with multiple i225-V, it replaced the i225-V firmware 1.87(1.57) of one network controller with the i226-V firmware before I noticed my error. The flash tool created a backup of the old firmware, but when I try the rollback mode "-r", it always ends with "Flash update failed" at 30%. When I add the line "IMAGE DOWNGRADE: TRUE" to nvmupdate.cfg and use the regular update mode "-u", I can see the controller with version 2.54(2.36) and a status of "Update available". I start the update, but it always ends with "Device update failed" followed by "Warning: VPD area not valid". Neither "-f" (Force the NVM update) nor "-sv" (Skip verification) helps.
3 Antworten
Amina_Sadiya
Mitarbeiter
867Aufrufe
Hello NRGSupport,
Greetings from Intel!
Thank you for contacting Intel. To proceed further with your query, we kindly request you to confirm the system on which the controller is installed. Additionally, please let us know where you obtained the firmware package.
Amina
Amina_Sadiya
Mitarbeiter
645Aufrufe
Hello NRGSupport,
Greetings from Intel.
This is the follow-up regarding the reported issue. We're eager to ensure a swift resolution and would appreciate an updates or additional information regarding the information we have requested for.
If we don't hear back from you, we'll assume the issue has been resolved and will proceed to close the case.
Please feel free to respond to this email at your earliest convenience.
Amina
Amina_Sadiya
Mitarbeiter
442Aufrufe
Hello NRGSupport,
This is a final follow-up regarding the reported issue. As we have not heard back from you, we'll assume the issue has been resolved and will proceed to close the case.
Amina
Antworten
