Ethernet Products
5869 Discussions
Flow Bifurcation - XXV710 for 25GbE SFP28 (rev 02)
ns-rlewkowicz
This bug outlines the technologies I'm using to attempt to create VFs.
https://github.com/k8snetworkplumbingwg/sriov-network-operator/issues/716
My goal is VF's in SRIOV mode and VFs in iavf mode. But this might not be possible on the 700 cards? Can intel rep confirm this?
Azeem_Intel
Hi ns-rlewkowicz,
Greeting for the Day!
I hope you are doing well. Could you please share a snapshot of the part with the serial number visible? Additionally, could you let us know if this product was shipped with the system or purchased separately?
Please do not hesitate in contact us, we are more than glad to assist you.
Azeem_Intel.
Azeem_Intel
Hi ns-rlewkowicz,
This is the first follow-up regarding the issue (Flow Bifurcation - XXV710 for 25GbE SFP28 (rev 02)) you reported to us.
We wanted to inquire whether you had the opportunity to review the plan of action (POA) we provided
Azeem_Intel.
Azeem_Intel
Hi ns-rlewkowicz,
This is the second follow-up regarding the reported issue. We're eager to ensure a swift resolution and would appreciate any updates or additional information you can provide.
Azeem_Intel.
Azeem_Intel
Hi ns-rlewkowicz,
This is the third follow-up regarding the reported issue. We're committed to ensuring a swift resolution and would greatly appreciate any updates or additional information you can provide.
If we don't hear back from you soon, we'll assume the issue has been resolved and will proceed to close the case.
Azeem_Intel.
Dambles
Hello Azeeom,
I am taking over on this issue from Ryan.
does this get you the info that you need?
root@knode03:/# lspci | grep -i eth
01:00.0 Ethernet controller: Intel Corporation Ethernet Controller XXV710 for 25GbE SFP28 (rev 02)
01:00.1 Ethernet controller: Intel Corporation Ethernet Controller XXV710 for 25GbE SFP28 (rev 02)
Dambles
root@knode03:~# lspci -d 8086: -v
Subsystem: Super Micro Computer Inc Ethernet Controller XXV710 for 25GbE SFP28
Flags: bus master, fast devsel, latency 0, IRQ 115, NUMA node 0
Memory at f7000000 (64-bit, prefetchable) [size=16M]
Memory at f8808000 (64-bit, prefetchable) [size=32K]
Expansion ROM at f9f80000 [disabled] [size=512K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [70] MSI-X: Enable+ Count=129 Masked-
Capabilities: [a0] Express Endpoint, MSI 00
Capabilities: [e0] Vital Product Data
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Device Serial Number de-50-dc-ff-ff-ef-ec-3c
Capabilities: [150] Alternative Routing-ID Interpretation (ARI)
Capabilities: [160] Single Root I/O Virtualization (SR-IOV)
Capabilities: [1a0] Transaction Processing Hints
Capabilities: [1b0] Access Control Services
Capabilities: [1d0] Secondary PCI Express
Kernel driver in use: i40e
Kernel modules: i40e
Memory at f6000000 (64-bit, prefetchable) [size=16M]
Memory at f8800000 (64-bit, prefetchable) [size=32K]
Expansion ROM at f9f00000 [disabled] [size=512K]
01:02.0 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Subsystem: Super Micro Computer Inc Ethernet Virtual Function 700 Series
Flags: fast devsel, NUMA node 0
Memory at f8400000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8910000 (64-bit, prefetchable) [virtual] [size=16K]
Capabilities: [70] MSI-X: Enable- Count=5 Masked-
Capabilities: [1d0] Access Control Services
Kernel driver in use: vfio-pci
Kernel modules: iavf
01:02.1 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8410000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8914000 (64-bit, prefetchable) [virtual] [size=16K]
01:02.2 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8420000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8918000 (64-bit, prefetchable) [virtual] [size=16K]
01:02.3 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8430000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f891c000 (64-bit, prefetchable) [virtual] [size=16K]
01:02.4 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8440000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8920000 (64-bit, prefetchable) [virtual] [size=16K]
01:02.5 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8450000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8924000 (64-bit, prefetchable) [virtual] [size=16K]
01:02.6 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8460000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8928000 (64-bit, prefetchable) [virtual] [size=16K]
01:02.7 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Flags: bus master, fast devsel, latency 0, NUMA node 0
Memory at f8470000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f892c000 (64-bit, prefetchable) [virtual] [size=16K]
01:03.0 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8480000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8930000 (64-bit, prefetchable) [virtual] [size=16K]
01:03.1 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8490000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8934000 (64-bit, prefetchable) [virtual] [size=16K]
01:03.2 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f84a0000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8938000 (64-bit, prefetchable) [virtual] [size=16K]
01:03.3 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f84b0000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f893c000 (64-bit, prefetchable) [virtual] [size=16K]
01:03.4 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f84c0000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8940000 (64-bit, prefetchable) [virtual] [size=16K]
01:03.5 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f84d0000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8944000 (64-bit, prefetchable) [virtual] [size=16K]
01:03.6 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f84e0000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8948000 (64-bit, prefetchable) [virtual] [size=16K]
01:03.7 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f84f0000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f894c000 (64-bit, prefetchable) [virtual] [size=16K]
01:04.0 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8500000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8950000 (64-bit, prefetchable) [virtual] [size=16K]
01:04.1 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8510000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8954000 (64-bit, prefetchable) [virtual] [size=16K]
01:04.2 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8520000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8958000 (64-bit, prefetchable) [virtual] [size=16K]
01:04.3 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8530000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f895c000 (64-bit, prefetchable) [virtual] [size=16K]
01:04.4 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8540000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8960000 (64-bit, prefetchable) [virtual] [size=16K]
01:04.5 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8550000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8964000 (64-bit, prefetchable) [virtual] [size=16K]
01:04.6 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8560000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8968000 (64-bit, prefetchable) [virtual] [size=16K]
01:04.7 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8570000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f896c000 (64-bit, prefetchable) [virtual] [size=16K]
01:05.0 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8580000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8970000 (64-bit, prefetchable) [virtual] [size=16K]
Capabilities: [70] MSI-X: Enable+ Count=5 Masked-
Kernel driver in use: iavf
01:0a.0 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8000000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8810000 (64-bit, prefetchable) [virtual] [size=16K]
01:0a.1 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8010000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8814000 (64-bit, prefetchable) [virtual] [size=16K]
01:0a.2 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8020000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8818000 (64-bit, prefetchable) [virtual] [size=16K]
01:0a.3 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8030000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f881c000 (64-bit, prefetchable) [virtual] [size=16K]
01:0a.4 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8040000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8820000 (64-bit, prefetchable) [virtual] [size=16K]
01:0a.5 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8050000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8824000 (64-bit, prefetchable) [virtual] [size=16K]
01:0a.6 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8060000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8828000 (64-bit, prefetchable) [virtual] [size=16K]
01:0a.7 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8070000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f882c000 (64-bit, prefetchable) [virtual] [size=16K]
01:0b.0 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8080000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8830000 (64-bit, prefetchable) [virtual] [size=16K]
01:0b.1 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8090000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8834000 (64-bit, prefetchable) [virtual] [size=16K]
01:0b.2 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f80a0000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8838000 (64-bit, prefetchable) [virtual] [size=16K]
01:0b.3 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f80b0000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f883c000 (64-bit, prefetchable) [virtual] [size=16K]
01:0b.4 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f80c0000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8840000 (64-bit, prefetchable) [virtual] [size=16K]
01:0b.5 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f80d0000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8844000 (64-bit, prefetchable) [virtual] [size=16K]
01:0b.6 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f80e0000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8848000 (64-bit, prefetchable) [virtual] [size=16K]
01:0b.7 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f80f0000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f884c000 (64-bit, prefetchable) [virtual] [size=16K]
01:0c.0 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8100000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8850000 (64-bit, prefetchable) [virtual] [size=16K]
01:0c.1 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8110000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8854000 (64-bit, prefetchable) [virtual] [size=16K]
01:0c.2 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8120000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8858000 (64-bit, prefetchable) [virtual] [size=16K]
01:0c.3 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8130000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f885c000 (64-bit, prefetchable) [virtual] [size=16K]
01:0c.4 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8140000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8860000 (64-bit, prefetchable) [virtual] [size=16K]
01:0c.5 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8150000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8864000 (64-bit, prefetchable) [virtual] [size=16K]
01:0c.6 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8160000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8868000 (64-bit, prefetchable) [virtual] [size=16K]
01:0c.7 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8170000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f886c000 (64-bit, prefetchable) [virtual] [size=16K]
01:0d.0 Ethernet controller: Intel Corporation Ethernet Virtual Function 700 Series (rev 02)
Memory at f8180000 (64-bit, prefetchable) [virtual] [size=64K]
Memory at f8870000 (64-bit, prefetchable) [virtual] [size=16K]
Dambles
