Ethernet Products
5868 Discussions
GTP DDP profile
Jiang
In the document Dynamic_Device_Personalization_GTP_Ext_Headers.pdf:
Is there any difference between pctype 16(17) and 18(19) ? Did you make a mistake?
Two of them should be UL, right?
Table 4.
Packet Classifier Types and Input Set
PCTYPE
PCTYPE Description
Hash Input Set
FD Input Set
12
IPv4 PFCP Session
IP4-S, IP4-D
13
IPv4 PFCP Node
IP4-S, IP4-D
14
IPv6 PFCP Session
IP6-S, IP6-D
15
IPv6 PFCP Node
IP6-S, IP6-D
16
GTP-U, PDU Type DL, IPv4 PDU
IP4-S, GTP TEID
GTP TEID
17
GTP-U, PDU Type DL, IPv6 PDU
IP6-S, GTP TEID
GTP TEID
18
IP4-D, GTP TEID
GTP TEID
19
IP6-D, GTP TEID
GTP TEID
22
GTP-U, IPv4 PDU
IP4-S, IP4-D, GTP TEID
GTP TEID
23
GTP-U, IPv6 PDU
IP6-S, IP6-D, GTP TEID
GTP TEID
24
GTP-U, non PDU
GTP TEID
GTP TEID
25
GTP-C, IPv4
GTP TEID
GTP TEID
38
GTP-C, IPv6
GTP TEID
GTP TEID
AlfredoS_Intel
Hi Jiang,
Thank you for posting on our Intel® Ethernet Communities Page.
Your inquiry may be better suited to be handled by another department. May we know if the information you are inquiring about is regarding a custom-built design where you plan to use our Intel® Ethernet Controller chips?
We look forward to hearing from you. If we do not get your reply, we will follow up after three business days.
Alfred S
Intel® Customer Support
AlfredoS_Intel
Hi Jiang,
We are just following up.
It looks like you need more time to provide the information that we asked for.
We will follow up again after 3 business days. Should we not hear from you, our system may automatically close the thread.
Alfred S
Intel Customer Support
AlfredoS_Intel
Hi Jiang,
We need to close this thread since we have not gotten a response from you: maybe because you are busy or preoccupied at the moment. We know that this is important for you to get it resolved, and it is also equally important for us to give you the right solution; as much as we would like to assist you, we need to close it to attend to other customers. We hope for your consideration and understanding on this one.
If you need any additional information, please submit a new question, as this thread will no longer being monitored.
Thank you for contacting Intel®, and have a great week!
Alfred S
