Ethernet Products
5868 Discussions
I219-V用のドライバーの使い方
wadai
CentOS7をインストールしたサーバでオンボードのNICが使えません。
# nmcli device
DEVICE TYPE STATE CONNECTION
enp1s0 ethernet 接続済み enp1s0
lo loopback 管理無し --
# lspci | grep Ethernet
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (12) I219-V
01:00.0 Ethernet controller: Intel Corporation 82574L Gigabit Network Connection
たぶんI219-VがオンボードのNICと思うのでドライバーを調べましたが、以下のページでは使い方が書いていないので、使い方を教えていただきたいです。
https://downloadcenter.intel.com/ja/download/22283/-Ethernet-Adapter-
お手数ですが、よろしくお願い致します。
Mike_Intel
Hello wadai,
I am very sorry, we can only support you in English and we are just using our own translator tool to understand your inquiry so please reply to us in English.
As per your inquiry, base on the link below your I219-V does not support Centos OS.
https://www.intel.com/content/www/us/en/support/articles/000055236/network-and-i-o/ethernet-products.html
And as stated at the top of the page, these cards are onboard. So for further checking of the supported OS of the board where the card is embedded and to get the appropriate driver, it is best to contact the manufacturer of the board.
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Mike_Intel
Hello wadai,
I hope you are having a good day. I just want to check if you already tried contacting the manufacturer of your board
to further check this issue.
Michael L.
Mike_Intel
Hello wadai,
I am sending another follow up to check if you have clarifications.
If you need further assistance, please post a new question.
Thank you.
Michael L.
