Ethernet Products
5743 Discussions
Help to setup an Ethernet connection
MCara4
New Contributor III
I need help to setup an Ethernet connection with a static or dynamic IP. I read other posts on this topic but I was unable to have a working configuration.
I have an USB Ethernet adapter that is recognized by Edison.
# dmesg | tail
[ 738.480773] asix 1-1:1.0 eth0: register 'asix' at usb-dwc3-host.2-1, ASIX AX88772 USB 2.0 Ethernet, 9c:eb:e8:0f:52:b3
[ 738.539534] systemd-udevd[372]: renamed network interface eth0 to enp0s17u1
ip a
5: enp0s17u1: mtu 1500 qdisc noop qlen 1000
link/ether 9c:eb:e8:0f:52:b3 brd ff:ff:ff:ff:ff:ff
Now I need to use connman to setup the ethernet interface. I did the following steps:
systemctl start connman
connmanctl disable wifi
connmanctl config ethernet_9cebe80f52b3_cable --ipv4 manual 192.168.0.199 255.255.255.0 192.168.0.1
Error ethernet_9cebe80f52b3_cable: Method "SetProperty" with signature "sv" on interface "net.connman.Service" doesn't exist
It seems clear that I missed something. Probably I give the wrong service name. I found on the web that
general format for a wired connection is: ethernet__cable
Can you please help me?
Carlos_M_Intel
Hi massca
What is the output of running:
root@edison:~# ip address
Also run the next line in the board:
root@edison:~# systemctl enable connman && systemctl start connman
If you still having problems try to get down the other interfaces:
root@edison:~# ifconfig wlan0 down
And as you were doing:
root@edison:~# connmanctl disable wifi
Let me know the output of ip address and what happens after enabling the connman service.
Regards;
CMata
MCara4
New Contributor III
Hi CMata_Intel,
below what you asked for. I'd like to know what is the standard procedure to setup an Ethernet connection on Edison. It seems me a basic requirements.
ip address
1: lo: mtu 65536 qdisc noqueue
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: sit0: mtu 1480 qdisc noop
link/sit 0.0.0.0 brd 0.0.0.0
3: wlan0: mtu 1500 qdisc pfifo_fast qlen 1000
link/ether fc:c2:de:39:71:fd brd ff:ff:ff:ff:ff:ff
inet 192.168.0.5/24 scope global wlan0
4: usb0: mtu 1500 qdisc pfifo_fast qlen 1000
link/ether 02:00:86:86:be:e6 brd ff:ff:ff:ff:ff:ff
inet 192.168.2.15/24 brd 192.168.2.255 scope global usb0
6: enp0s17u1: mtu 1500 qdisc noop qlen 1000
ln -s '/lib/systemd/system/connman.service' '/etc/systemd/system/multi-user.target.wants/connman.service'
ifconfig wlan0 down
Disabled wifi
ip address
As you can see the enp0s17u1 interface (ethernet) doesn't get an IP. It needs additional configuration.
Brendan_L_Intel
MCara4
New Contributor III
Hi arfoll,
it works! Thank you very much!
Now I need to find a way to persist this configuration to the Edison reboot. Can you please help me?
MCara4
New Contributor III
Hi arfoll, CMata_Intel,
I put a script in /etc/init.d/ to disable wifi and start udhcpc.
This could be a solution, I'd like to use connmanctl at user level, ie not root, to disable wifi and start dhcp on ethernet.
Any suggestion?
Brendan_L_Intel
Here's what I did:
connmnanctl
connmanctl> enable ethernet
connmanctl> services
*A0 Wired ethernet_00106031716e_cable
connmanctl> config ethernet_00106031716e_cable --ipv4 dhcp
So that makes ethernet dhcp persistent. To let other users change network configs (i.e. none root), you'll need to change connman dbus settings since thats what connmanctl uses which is controled by /etc/dbus-1/system.d/connman.conf. First make a user.
useradd -m arfoll
passwd
vi /etc/dbus-1/system.d/connman.conf
Make it look like this (just switch user="root" to group="network")
<!DOCTYPE busconfig PUBLIC "-//freedesktop//DTD D-BUS Bus Configuration 1.0//EN"
"http://www.freedesktop.org/standards/dbus/1.0/busconfig.dtd http://www.freedesktop.org/standards/dbus/1.0/busconfig.dtd">
Then set the network group up, rebooting is easier & safer than reloading dbus configs so lets just do that.
groupadd network
gpasswd -a arfoll network
reboot
Login as 'arfoll' and go crazy:
connmanctl
connmanctl> disconnect ethernet_00106031716e_cable
Disconnected ethernet_00106031716e_cable
connmanctl> connect ethernet_00106031716e_cable
Connected ethernet_00106031716e_cable
MCara4
New Contributor III
Hi arfoll,
it works perfectly, you made me very happy!
I hope Intel will include your solution in an official Edison networking guide.
-max
