Ethernet Products
5707 Discussions
How to implement I210 errata workaround case 31?
Zhangbin
This is a follow-up to anther discussion:
I210 TX qeueu stalled randomly during long-term operation
@Devi_Intel
Very strange I cannot reply on that discussion, so post a new one there:
I210 spec update suggests user to disable ipv6 extension (set bit 16 in RFCTL register) to fix the I210 errata case 31:
but the bit 16 of RFCTL in I210 datasheet is stated as reserved, there is no meaning to set bit16 to 1:
So could you please kindly suggest me how to follow I210 spec update to implement the workaround of I210 spec update errata case 31?
Sam
