Ethernet Products
5764 Discussions
Intel 210 software stack
Daniel-O
How to flash the Intel210 software stack on the NVIDIA JETSON, ive had a look at some of the comments highlighted in red:
The (https://edc.intel.com/Link.aspx?id=3815)Intel(R) Network Connections Tools document # 348742 has the Eeupdate.
This file is classified as Intel confidential, which requires a CDNA between you and Intel as well as an Embedded Design Center (EDC) Privileged account that should be requested by going to
https://www.intel.com/content/www/us/en/design/support/account-support.html%C2%A0https://www.intel.com/content/www/us/en/design/support/account-support.html
could you help find a gateway for the licence under NDA
ArpanB_Intel
Hi Daniel, could you confirm full name of the Intel® product you are using?
We would like to know.
Daniel-O
Product - Intel I210 controller
ArpanB_Intel
Daniel, thank you for the confirmation. We will move the product to the relevant forum for further support.
IntelSupport
Community Manager
Hello Mr Daniel,
Good Day ~
I'm here to follow up case as per subject. Appreciated you can advise the full name of the Intel product you are using. Looking forward to hear from you.
Thank You & Regards,
Devi
Intel Technical Support
IntelSupport
Community Manager
Hello Mr Daniel,
Good Day ~
Apologize on the previous email regarding the product detail. Appreciated you can advise the issue of the system you facing. Looking forward to hear from you.
Devi
Daniel-O
We are looking to add an additional Gbit Ethernet connection (so there will be 2 in total) to an Nvidia jetson. The module incorporates 1 and I was planning to use the PCIe1 to connect something like the Intel I210 controller (unless you can recommend a better supported device?). Will the module support this on PCIe1 if I have an NVMe module connected to PCIe0?
this issues is
I have been trying to get the software and firmware required to program the i210 directly from intel and have had no luck.
As you know we are using the nvidia Arm module and require a version of the EEUPDATE to program the i210 and the correct firmware that gets programmed into the device.
The i210 chip appears to come unprogrammed and purely based on some Googling I think I need these items but I could be wrong.
Intel have told me to approach one of their partners as it takes a long time to approve our company as a partner to get the software.
IntelSupport
Community Manager
Hello Mr Daniel,
Good Day
I apologize for the delay in replying. Appreciate your can advise what was the suggestion or solution given by the local partners, We regret to inform we have limited accessibility as local partner has. We apologize for any inconvenience caused. For further concern please do let us know.
Thanks & Best Regards,
Devi_ Intel Technical Support
Devi_Intel
Greeting Daniel,
Your issue is now considered resolved, therefore we are proceeding to close this ticket.
If you have any more questions in the future, please don't hesitate to post a new question, as this thread will no longer be monitored.
Thank You & Regards
Devi_Intel
