Ethernet Products
5677 Discussions
How to install controller for 17 I219-LM on ubuntu22.04?
ruonan
I try install https://www.intel.com/content/www/us/en/download/14611/intel-network-adapter-driver-for-pcie-intel-gigabit-ethernet-network-connections-under-linux-final-release.html?,  but get error when make install , error looks like
error "struct xdp_umem" has no member named 'pages' 'pgs'
I also tried install https://www.intel.com/content/www/us/en/download/15084/intel-ethernet-adapter-complete-driver-pack.html, but I don't understand the content after unzip and don't know what to do.
My Linux kernel version is Linux 5.15.0-48-generic x86_64
My Linux version is Ubuntu22.04 TLS.
Processor is Intel® Core™ i9-12900 Processor.
Now I am struggling to install ethernet controller on ubuntu22.04.
Reha
Did you try the version "e1000e-3.8.7.tar.gz"
The latest version is here https://sourceforge.net/projects/e1000/files/e1000e%20historic%20archive/
Or you can download from the Intel site :
https://www.intel.com/content/www/us/en/download/14611/15817/intel-network-adapter-driver-for-pcie-intel-gigabit-ethernet-network-connections-under-linux-final-release.html?
Installation instruction is in README Text files ( readme.txt )
Hope it helps
ruonan
Thanks for your reply!
I have tried version "e1000e-3.8.7.tar.gz" but still can't make install.
The error now looks like this:
'/usr/local/src/e1000e/e1000e-3.8.7/src/ethtool.c:2828:35: error: initialization of 'int (*)(struct net device *, struct ethtool_coalesce *, struct kernel_ethtoll_coalecse *, struct netlink_ext_ack *)' form incompatible pointer type 'int (*)(struct net device *, struct ethtool_coalesce *)' '' [-Werror=incompatible-pointer-types]
azeitonaverde
This worked! Thanks
My versions:
Description: Ubuntu 20.04.6 LTS
kernel: 5.4.19-rt11
Reha
I guess the kernel Linux 5.15.0-48 is not supported .
I have recently compiled this driver with the kernel version 15.10.0-18  without any problem ,  if you can go back kernel version 5.10 it will work i think.
ruonan
Thanks ! I will have a try. By the way, I wonder your gcc version is ?
ruonan
This solution saves me ! Thanks a lot!!!
Reha
My gcc version is 10.2.1
Mike_Intel
Hello ruonan,
We are glad that the issue has been answered. Just checking if you still have clarification regarding this thread.
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel® Customer Support
Mike_Intel
Hello ruonan,
I hope you're having a wonderful day. I am just sending a soft follow up to check if you still have clarifications. We will wait for your reply.
Michael L.
ruonan
Thanks for your help! I have no  clarifications now.
Mike_Intel
Hello ruonan,
Thank you for the quick reply and update. We will close this case now and if you need assistance again in the future, please post a new question.
Thank you and stay safe.
Michael L.
mitrix
Hello Mike, I have the same problem. Laptop Dell 5420, I219-LM. On Ubuntu 20.04 I compiled the e1000e driver (https://www.intel.com/content/www/us/en/download/14611/15817/intel-network-adapter-driver-for-pcie-intel-gigabit-ethernet-network-connections-under-linux-final-release.html). On Ubuntu 20.04 it works stably. When upgrading the kernel to 22.04, the e1000e driver does not load. When I try to compile again from the sources, an error occurs. New IGB drivers (https://www.intel.com/content/www/us/en/download/15084/intel-ethernet-adapter-complete-driver-pack.html) recommended by Intel for this adapter are loaded into the kernel, but the adapter does not work.
