Ethernet Products
5707 Discussions
How to set multi vlan id use SR-IOV
IIsht
I have use SR-IOV in my proxmox, and I was passthrough 2 virtual Function NIC card to my vm-pfsense
[code]
root@pve:~# lspci |grep Eth|grep I350
07:00.0 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
07:00.1 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
08:10.0 Ethernet controller: Intel Corporation I350 Ethernet Controller Virtual Function (rev 01)
08:10.1 Ethernet controller: Intel Corporation I350 Ethernet Controller Virtual Function (rev 01)
08:10.4 Ethernet controller: Intel Corporation I350 Ethernet Controller Virtual Function (rev 01)
08:10.5 Ethernet controller: Intel Corporation I350 Ethernet Controller Virtual Function (rev 01)
08:11.1 Ethernet controller: Intel Corporation I350 Ethernet Controller Virtual Function (rev 01)
[/code]
But one of ethernet port have to tag 2 vlan id
[code]
root@pve:~# ip link show eth11
6: eth11: mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
link/ether 0c:c4:7a:c3:9f:07 brd ff:ff:ff:ff:ff:ff
vf 0 MAC 7e:ba:b6:b5:ec:13, spoof checking on, link-state auto
vf 1 MAC 7e:ba:b6:b5:ec:14, spoof checking on, link-state auto
vf 2 MAC 7e:ba:b6:b5:ec:15, vlan 300, spoof checking on, link-state auto
[/code]
I was use Trunk port in DGS-1510 switch, and I can see 7e:ba:b6:b5:ec:15 this mac tag vlan id 300 on switch web gui.
Any in pfsense, I can see 7e:ba:b6:b5:ec:15 this interface status was up. so I set static ip 192.168.55.1 on this interface.
But DGS-1510 and pfsense cannot ping each other.
How can I solve this error?
Hi silimms,
Thank you for the post. I will investigate on this then update you if there is any finding.
rgds,
wb
Hi silimms,
Can you share the rules set on the interface of pfsense that is trying to ping the VF that is on VLAN 300?
Are you able to ping successfully If you are trying to ping VF without VLAN tag?
Please share the ethtool -i of your eth11.
wb
Hi silimms,
Please feel free to provide the information requested on my previous post.
wb
IIsht
Hi wb,
I have allow all to LAN
http://i.imgur.com/JMxqusZ.png http://i.imgur.com/JMxqusZ.png
And Set vlan 300 at pfsense too.
root@pve:~# ethtool -i eth11
driver: igb
version: 5.3.4.4
firmware-version: 1.63, 0x800009fa
bus-info: 0000:07:00.1
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: no
Hi slimms,
Thank you for the information. Are you able to ping successfully If you are trying to ping VF without VLAN tag?
wb
Hi Slimms,
SR-IOV should support VLAN. Please update me if you have tried the connection between VM_Pfsense and D-link switch without VlAN? If there is no issue, you can check the setting on your Pfsense or switch.
rgds,
wb
IIsht
Hi wb,
I've solved this problem,
I can't tag any vlan on proxmox and pfsense.
And I need to set hybrid on D-Link switch(cannot use trunk)
When I do this, it's working now.
thanks your help.
Hi Silimms,
Thank you for sharing the information, glad the issue is fixed.
rgds,
wb
