Ethernet Products
5861 Discussions
I210-IT operation
HTang7
I am design in the I210-IT device and just wondering if I need to program any image to the iNVM internal to the device in order to get the device manger to recognize the device.
I am using windows 7.
HTang7
Hi Adolfo,
Finally, I am be able to get the i210 working. Thank you so much for all the help....
one more question, I use the conlanfw32.exe to open the adapter manual.
Sometime I can't initialize the i210.
When I go to the FLASH menu, the READ and WRITE flash have been gray out.
I can't program the flash memory.
Do you know why?
Henry
Adolfo_S_Intel
Hi HenryT
Is your problem with the flash sporadic?
Are you using the flash or the iNVM image?
What image file are you using? Did you make any modification to the file before programming?
Adolfo
HTang7
Hi Adolfo,
Is your problem with the flash sporadic? I have to disable the driver from window before initialize the chip. Sometime, I can program it and sometime I can't. I don't know why.
Are you using the flash or the iNVM image? I am using flash image now.
I am using traditional_from_3.11_4Mb.bin. I don't know how to modify the file. Anyway to modify this file?
Henry
Adolfo_S_Intel
Hello HenryT
Yes you always have to disable the windows driver before using the LANConf tool.
You cannot modify binary files, you can only modify .hex image files or the configuration files used to program the iNVM.
I think your problem might be related to power cycles. Do you perform a full power cycle after every successful configuration?
Please check sections 2.10 and 2.25 of thehttps://www-ssl.intel.com/content/www/us/en/embedded/products/networking/ethernet-controller-i210-i211-faq.html Intel® Ethernet Controller I210/I211 FAQs
Adolfo.
ККучм
Hi Adolfo,
I need to program a couple of words in iNVM of i210-IS to use this chip in SerDes flashless mode.
But the EEUPDATE utility requires input configuration file with unknown to me format.
Could you please send me example of this file or the document describing its format.
Konstantin
CarlosAM_INTEL
Hello CPC1311,
Thanks for contacting Intel Embedded Community.
You should use the appropriate text file when programming the iNVM on an I210 device. This file can be found in the http://www.intel.com/content/www/us/en/secure/intelligent-systems/privileged/gbe-i210-i211-nvm-images.html Intel(R) Ethernet Controller I210 Production NVM Images document # 513655, as is stated on the answer to the question 2.14, on page 9 of the http://www.intel.com/content/dam/www/public/us/en/documents/faqs/ethernet-controller-i210-i211-faq.pdf Intel(R) Ethernet Controller I210/I211Frequently Asked Questions(FAQs). The document # 513655 is classified as Intel Confidential that would be accessible to you if update your Embedded Design Center (EDC) account to Privileged type. To request an upgrade from your Basic EDC account to a Privileged account, go to http://www.intel.com/content/www/us/en/embedded/embedded-design-center-support.html http://www.intel.com/content/www/us/en/embedded/embedded-design-center-support.html and click on "Manage Your Intel Profile" found in the "Manage Your Account" section of the page. From there you can request an upgrade. After you submit the application, please let us know and we will expedite the review of your application. The application can be found at:
https://www-ssl.intel.com/content/www/us/en/forms/intelligent-systems/registration-po.html https://www-ssl.intel.com/content/www/us/en/forms/intelligent-systems/registration-po.html
We suggest you use a business email address to evade any inconvenience. Please avoid the free email provider's address (such the provided by Hotmail, Gmail, yahoo, or others).
Please let us know if this information is useful to you.
Carlos A.
ILyak
Hello, AdolfoS
Is it possible to modify EATOOL source code to use it with PCI IO ports without IO memory?
Thank you.
Ilya Lyakh
CarlosAM_INTEL
​Hello, @ILyak​:
In order to be on the same page, we would like to address the following questions:
Could you please tell us if your request is related to a technical problem? In case that your answer is affirmative, please give us a detailed description of the issue.
Could you please confirm if this thread is related to a design developed by you or by a third-party company? If it is a third-party design, please let us know the model, part number, and where is stated the information related to it.
What is the document number and version of the " EATOOL" that you have mentioned?
Waiting for your answer.
@Mæcenas_INTEL​.
