Ethernet Products
5740 Discussions
I210 MAC Address Factory Setting
MBufa
Does the I210 ship with a unique MAC Address for each chip, or do MACs need to be purchased and manually assigned? In my experience it's always been the latter, but the manual has some bits that suggest that there's a unique factory setting that can be reapplied over a user MAC.
Hi Mdbetn,
Thank you for the post. According to the FAQ on page 9
"Fields that are normally subject to change by the OEM, such as the MAC address, PCI subsystem ID fields and LED customizations, can be changed without invalidating
the digital signature."
. http://www.intel.com/content/dam/www/public/us/en/documents/faqs/ethernet-controller-i210-i211-faq.pdf
But let me further check and provide you the updates. thank you.
rgds,
wb
Hi Mdbetn,
You can check on the information available below regarding the mac address
https://embedded.communities.intel.com/thread/7835
rgds,
wb
Hi Mdbetn,
Please feel fee to update if further assistance needed?
rgds,
wb
MBufa
wb,
My specific question is whether the I210 ships with a valid, unique MAC Address or whether one must be purchased and programmed by the implementer. I understand that it can be changed later by the end user. Right now I am trying to confirm that I will need to purchase a MAC Address for each I210.
Is it correct that I will need to purchase MAC Addresses for each I210 and assign them using the Network Config tools or the PCIe interface?
mdbetn
Hi Mdbetn,
Thank you for the clarification. Let me further check.
rgds,
wb
Hi Mdbetn,
Good day. You may contact our embedded communities support regarding your inquiries,
below is a similar inquiry found in our embedded communities that may address your concern:
https://embedded.communities.intel.com/thread/9313
You can contact them for further clarification. I hope this help
rgds,
wb
MBufa
wb,
Ok, so the I210 does not come with a pre-programmed MAC address. Figured that would be the case. Thanks.
mdbetn
Hi Mdbetn,
You are welcome. Thank you for your time on this matter.
rgds,
wb
