The chip model is WGI210AT. How to configure it to fiber mode in INVM? Can you provide me with a txt file in EEUpdate software? I found the txt file I210_invm_SerDesKX_APM-v0.6.txt online, and changed 0x0d=0x157C to 0x0d=0x1536 in fiber mode. Communication was not possible during testing. Here is all the content in txt:
;2013-04-07 IMGVER 0.6 IMGTYPE 3 ; I210 KX with APM ;==================================================================================== ; I N T E L P R O P R I E T A R Y ;COPYRIGHT (c) 1998 - 2012 BY INTEL CORPORATION. ALL RIGHTS RESERVED. ;NO PART OF THIS PROGRAM OR PUBLICATION MAY BE REPRODUCED, TRANSMITTED, TRANSCRIBED, ;STORED IN A RETRIEVAL SYSTEM, OR TRANSLATED INTO ANY LANGUAGE OR COMPUTER LANGUAGE ;IN ANY FORM OR BY ANY MEANS, ELECTRONIC, MECHANICAL, MAGNETIC, OPTICAL, CHEMICAL, ;MANUAL, OR OTHERWISE, WITHOUT THE PRIOR WRITTEN PERMISSION OF: ;INTEL CORPORATION ;2200 MISSION COLLEGE BOULEVARD ;SANTA CLARA, CALIFORNIA 95052-8119 ;Autoload commands configuration file for Flashless I210. ;SYNTAX: ;======= ; The following entries are allowed in file: ; Single command record entry: ; ============================ ; = ; Series of commands which must be applied in exact sequance ; =========================================================== ; Ordered_Section_Start ; <Single record entry #1> ; . ; . ; <Single record entry #N> ; Ordered_Section_End ; Pure comment line like the one you are looking at :-). ; ====================================================== ; Empty line with white characters only. ; ====================================================== ; where: ; <Record type> - record type: ; WALD - autoload word record ; CSRALD - CSR autoload record ; PHYALD - PHY autoload record ; <Address> - address in hexadecimal format from range: ; 0x00 - 0x2E in WALD records definition ; 0x00000 - 0x1FFFC (4 bytes alignment required) in CSRALD records definition ; 0x00 - 0x1F in PHYALD records definition ; <Data> - Data to set in hexadecimal format: ; 0x0000 - 0xFFFF in WALD and PHYALD records definition ; 0x00000000 - 0xFFFFFFFF in CSRALD records definition ; <Reset type> - describes set of reset events for which particular record data setting is to be applied: ; LPG_RST - LanPower Good Reset only ; PCIE_RST - PCIe asserted reset and all above ; SW_RST - Host software asserted device reset and all above ; <Comment> - any sequence of printable characters (including space and tab) starting with ';' ; Duplicates (records with the same value of fields: <Record type> <Address> and <Reset type>) shouldn't ; be defined outside ordered section. If both are found outside ordered section then all but the first found ; will be silently ignored by the commands parser. If one of them is defined in ordered section then its counterpart ; outside ordered section will be ignored as well. CSRALD 0x5ba0 = 0x00001541 LPG_RST ; [Intel] Set GPAR_EN from CSR auto config. WALD 0x0a = 0x402F PCIE_RST ; [Intel] Set GPAR_EN. WALD 0x1b = 0x3400 PCIE_RST ; [Intel] Default settings. WALD 0x28 = 0x1C60 PCIE_RST ; [Intel] FLBAR_Size = 000 WALD 0x29 = 0x003C PCIE_RST ; [Intel] Set Wake_pin_enable WALD 0x0d = 0x157C PCIE_RST ; [Intel] SerDes Device ID WALD 0x21 = 0x0584 PCIE_RST ; [Intel] Default settings. WALD 0x24 = 0x0690 PCIE_RST ; [Intel] Set APM; Link Mode = 01 (KX) WALD 0x0F = 0xF247 SW_RST ; [Intel] Set APMPME + SerDes Low Power Enable ; Common Customer Configurations ; ============================== ; Subsystem Vendor ID and Subsystem ID - Uncomment the following lines and insert the values. ; WALD 0x0B = 0x0000 PCIE_RST ; Subsystem ID ; WALD 0x0C = 0x8086 PCIE_RST ; Susbsystem Vendor ID ; ; Disable IO BAR - Uncomment the following line. ; WALD 0x19 = 0x3000 PCIE_RST ; Clear IO_Sup ; ; Non-default LED Configuration - Uncomment the following lines and set the values for the LED configuration. ; WALD 0x1C = 0x0784 PCIE_RST ; LED1 Config ; WALD 0x1F = 0x0706 PCIE_RST ; LED0,2 Config ; ; Enable Power-Down Modes - Uncomment the 1st line to enable power down with the DEV_OFF_N pin. ; Uncomment the 2nd line to enable the dynamic power down mode. ; Enabling both power down modes is not permitted. ; WALD 0x1E = 0xB200 PCIE_RST ; Enable DEV_OFF Power Down ; WALD 0x1E = 0x7200 PCIE_RST ; Power Down Settings ; ; LAN Power Consumption - Uncomment the following line and insert power data to be provided in the PCIe config space. ; WALD 0x22 = 0x0000 PCIE_RST ; LAN Power Consumption ; ; Watchdog Configuration - Uncomment the following line to enable the watchdog after reset. ; WALD 0x2E = 0x9000 SW_RST ; Enable watchdog ; Ordered_Section_Start CSRALD 0x5B44 = 0x00FF00A8 LPG_RST ; [Intel] Set NFTS to 0xA8. CSRALD 0x5B40 = 0x5E000090 LPG_RST ; [Intel] cont. Ordered_Section_End<Reset type>) shouldn't ; be defined outside ordered section. If both are found outside ordered section then all but the first found ; will be silently ignored by the commands parser. If one of them is defined in ordered section then its counterpart ; outside ordered section will be ignored as well. CSRALD 0x5ba0 = 0x00001541 LPG_RST ; [Intel] Set GPAR_EN from CSR auto config. WALD 0x0a = 0x402F PCIE_RST ; [Intel] Set GPAR_EN. WALD 0x1b = 0x3400 PCIE_RST ; [Intel] Default settings. WALD 0x28 = 0x1C60 PCIE_RST ; [Intel] FLBAR_Size = 000 WALD 0x29 = 0x003C PCIE_RST ; [Intel] Set Wake_pin_enable WALD 0x0d = 0x157C PCIE_RST ; [Intel] SerDes Device ID WALD 0x21 = 0x0584 PCIE_RST ; [Intel] Default settings. WALD 0x24 = 0x0690 PCIE_RST ; [Intel] Set APM; Link Mode = 01 (KX) WALD 0x0F = 0xF247 SW_RST ; [Intel] Set APMPME + SerDes Low Power Enable ; Common Customer Configurations ; ============================== ; Subsystem Vendor ID and Subsystem ID - Uncomment the following lines and insert the values. ; WALD 0x0B = 0x0000 PCIE_RST ; Subsystem ID ; WALD 0x0C = 0x8086 PCIE_RST ; Susbsystem Vendor ID ; ; Disable IO BAR - Uncomment the following line. ; WALD 0x19 = 0x3000 PCIE_RST ; Clear IO_Sup ; ; Non-default LED Configuration - Uncomment the following lines and set the values for the LED configuration. ; WALD 0x1C = 0x0784 PCIE_RST ; LED1 Config ; WALD 0x1F = 0x0706 PCIE_RST ; LED0,2 Config ; ; Enable Power-Down Modes - Uncomment the 1st line to enable power down with the DEV_OFF_N pin. ; Uncomment the 2nd line to enable the dynamic power down mode. ; Enabling both power down modes is not permitted. ; WALD 0x1E = 0xB200 PCIE_RST ; Enable DEV_OFF Power Down ; WALD 0x1E = 0x7200 PCIE_RST ; Power Down Settings ; ; LAN Power Consumption - Uncomment the following line and insert power data to be provided in the PCIe config space. ; WALD 0x22 = 0x0000 PCIE_RST ; LAN Power Consumption ; ; Watchdog Configuration - Uncomment the following line to enable the watchdog after reset. ; WALD 0x2E = 0x9000 SW_RST ; Enable watchdog ; Ordered_Section_Start CSRALD 0x5B44 = 0x00FF00A8 LPG_RST ; [Intel] Set NFTS to 0xA8. CSRALD 0x5B40 = 0x5E000090 LPG_RST ; [Intel] cont. Ordered_Section_End
Hello phsd,
Thank you for posting on Intel Community.
We understand that you are configuring the fiber mode in INVM and are looking for information regarding the EEUpdate software text file.
For the most accurate and detailed response, we kindly recommend submitting your query on the Intel® Embedded Connectivity Forum.
https://community.intel.com/t5/Embedded-Connectivity/bd-p/embedded-networking-connectivity
Vikas
