Ethernet Products
5742 Discussions
I210 disable GBE
Nora_Wang22
Hello Guys!
I've set bit 4 of 0x20 to 1b to disable GBE function, but it still reported GBE capability.
Should I modify other settings?
Thanks alot!
Sachinks
Hello Nora_Wang22,
Greetings! Thank you for the update.
As you have confirmed that you will be opening an IPS case, kindly let us know if we can archive this thread from our end.
Sachin KS
MACM
Hi Nora_Wang22,
Greetings of the day.
Hope you are doing well.
Could you please share us the complete model name of the Network adapter.
So that we can proceed further accordingly.
Mohammed Ali CM
Intel Customer Support
Nora_Wang22
Hello MACM,
Good Day!
We use the Intel® Ethernet Controller I210-IT, not a network adapter. Should I post to the other category?
Thanks a lot!
Nora.
Fikri_Intel
Hi Nora_Wang22,
Thank you for your response.
Would you be able to confirm with us what tool that you are using to disable the Gbe?
Fikri O.
Nora_Wang22
Hello Fikri_Intel
I used eeupdate64e to update the EEPROM of the i210.
Thanks!
Nora.
Dineshbabu
Hi Nora_Wang22,
Greetings!
Thank you for your response. Could you please provide the system or motherboard model?
Additionally, could you please assist us with the SSU logs? You can refer to the link below to generate the SSU logs.
Dinesh
Nora_Wang22
Hello Dinesh
The CPU is Intel Atom E3940, but our customer's OS is Linux system not windows. Should we provide SSU logs? This software runs under windows. Thanks!
Nora.
Fikri_Intel
Hi Nora_Wang22,
To assist you further, kindly refer to the datasheet which provides comprehensive information on the controller's features, including EEPROM configurations. https://cdrdv2.intel.com/v1/dl/getcontent/333016
Additionally, you can refer to the adapter user guide which contains some information as well:
https://www.intel.com/content/www/us/en/download/19373/adapter-user-guide-for-intel-ethernet-adapters.html
If you require further assistance, we recommend you open an IPS case please for direct assistance. The IPS team will be able to provide additional support regarding the issue. Instructions for opening an IPS case can be found here:
https://www.intel.com/content/www/us/en/support/articles/000057045/ethernet-products.html
Fikri O.
Nora_Wang22
Hello Fikri,
Thank you, I'm going to open this issue to IPS.
Nora.
Sachinks
Hello Nora_Wang22,
Sachin KS
Nora_Wang22
Hello Sachin KS
I've opened this IPS case so please close this item.
Thanks alot!
Nora.
