Ethernet Products
5505 Discussions
I219-LM EAP Identity-Request ( NAC ) ignored intermittently
NAC
We have observed both on HP and Dell laptops and workstations that if they are using Intel I219-LM NIC they intermittently do not respond to EAP Identity-Request.
We have excluded and have confirmed with Cisco and Microsoft TAC any other potential root causes and we are left with the Intel I219-LM as single common factor. We have additionally confirmed this by using Ethernet adapters/Docking stations successfully as workaround.
Multiple driver versions have been attempted but the issue persist nevertheless.
This is currently being investigated via a collaboration with Dell - Intel but we are hopeful of getting any additional information from anyone who've had this issue as it's adding unnecessary complexity to our NAC rollout and creating incidents when new devices with this NIC are not manually allowed MAB. Affected HP / Dell models with this NIC:
Dell Latitude 5540, Delll Latitude 5440 and Dell Latitude 5530 , Dell OptiPlex 3000 Small Form Factor
HP EliteBook 850 G3
HP EliteBook 850 G5
HP ProDesk 600 G2 DM
HP ProDesk 600 G2 MT
HP ProDesk 600 G3 MT
HP ProDesk 600 G4 MT
HP ProDesk 600 G5 MT
vij1
Hello Nac,
Greetings!
Could you please share the current driver version of the NIC you are using?
Additionally, please confirm whether the NIC you are using is an add-on or built-in.
Could you also provide the operating system details?
Vijay N.
vij1
Hello Nac,
Greetings!
We are following up to find out if you were able to complete the actions, we previously recommended. Please reply to confirm, so we can continue helping on a resolution. Looking forward to receiving your reply.
Vijay N.
vij1
Hello Nac,
Greetings!
We have not received a reply from you , and as such, we will be closing your case.
If you want to continue support, please reply to this post and we will reopen your case or create a new one so that we can continue to support you.
Vijay N
