Ethernet Products
5821 Discussions
I219-V Server 2016 driver support
OKara8
I purchased the Z270-TOMAHAWK for use on my server computer.
Before buying, I checked the ethernet card and saw that it supports server 2016.
However, ethernet driver server 2016 can not setup. I tried as installation and inf no solution.
I've introduced it as an I219-VM now, but I know it's not working properly.
I expect support from the authorities as soon as possible.
AlHill
OKara8
I'm very upset about this answer.
I've tried all the drivers that Intel has published.
However, it works with the driver I provided with drp.su.
I don't want to use drp.su. Why did the driver I downloaded from intel not work?
OKara8
AlHill
I gave you the link to the latest driver package for Server 2016.
I have checked and your board does not support Server 2016.
You will have to wait for the "authorities", also known as Support Engineers.
Doc
OKara8
Ancak Intel'in sitesi yazmayı gerektirir.
Beni mağdur etme hakkın var mı?
Anakartımı sitenizden bakarım içindir göre aldım.
Çözüm için ne yapacaksınız?
AlHill
I have already provided you the proper link for Server 2016. There is nothing more I can do to help you.
I am not victimizing you. Look at the MSI support site. You will not find Server 2016 in the list of supported Operating systems for your board.
https://www.msi.com/Motherboard/support/Z270-TOMAHAWK#down-driver
The announcement on the forum main page:
Intel closed Dec.25 and Jan 1, peer support only
Intel Customer Support will be observing the holidays on Wednesday, Dec. 25th, and Wednesday, January 1st. There will be no Intel support at this time, only support offered by peers in the community. Thank you and thanks to those helping each other out over the holidays!
So, you must wait.
Doc
