Happens a few times every session. I have updated the driver from the MB manufacturer site as well as Intel's. I have also changed the power management settings to not allow it to get turned off. I have tried changing the speed and duplex. Nothing has worked. I'd rather not deal with a warranty claim with the MB manufacturer and having to replace the MB. Is there anything else I can try? Are there logs or a program I can use to determine the actual cause for the disconnects? Any help is appreciated!
Hi Krhamm,
Greetings for the day!
Hope you are doing well. Could you please confirm if this product was purchased separately or if it was shipped with the system, additionally have you tried to update driver.
Please do not hesitate in contact us, we are more than glad to assist you.
Azeem_Intel
Thanks for the response! I purchased a motherboard for my PC that has the I225-V LAN Adapter. I have updated the driver, from both the motherboard's manufacturer site and Intel's site. Neither driver has corrected the issue.
Hi Krhamm,
Thank you for confirming. Since the product was shipped with the system, I recommend reaching out to your OEM team regarding this issue. They should be able to provide further assistance and support.
Azeem_Intel
