Ethernet Products
5706 Discussions
I226-LM WOL issue
Ilpo
Hope this is the correct forum to ask this question.
I have been testing I226-T1 NIC (with I226-LM controller) in both Windows 11 and Linux (Mint 22). If the cable is connected to a switch port that supports 10M link, WOL works with both setups. If the port does not support 10Mbps, WOL works only in Windows (link is up at 100M when in sleep mode).
How do I configure the sleep mode link speed to support 100M in Linux as well?
Where can I find the datasheet for I226-LM?
Subhashish
Hello Ilpo,
Greetings from Intel !!
This is to inform you that based on your query, you have to post this question in Intel Embedded Connectivity Forum (Link shared below):
https://community.intel.com/t5/Embedded-Connectivity/bd-p/embedded-networking-connectivity
Please confirm if you have used this link.
In addition to this, you may refer to below article:
https://www.intel.com/content/www/us/en/support/articles/000092457.html
Subhashish_Intel.
Ilpo
I have tried to post my questions to "Embedded Connectivity"..
"Ilpo (Beginner) posted a new topic in Embedded Connectivity on 12-01-2024 11:37 PM:"
Not sure what's happening but any real help on the issue would be appreciated.
Sreelakshmi1
Hello Ilpo,
Greetings!
Thank you for confirming. Could you please provide a screenshot of the post you made in Intel Embedded Connectivity for verification?
Sreelakshmi Balakrishnan
Intel customer support Technician
intel.com/vroc
Ilpo
The post is no longer visible there. The link in the post confirmation email points here even though it says the topic is in "Embedded Connectivity".
Sazirah
Hi Ilpo,
Upon double checking on this issue, you may want to refer to link below for the required information regarding the datasheet of Intel® Ethernet Controller I226.
https://www.intel.com/content/www/us/en/secure/content-details/596659/intel-ethernet-controller-i225-i226-datasheet.html?wapkw=i226%20lm%20datasheet
Please take note that this datasheet document may be restricted due to confidential data, and require you to have access for the Intel Premier DevZone. If you do not have the access, you can request the access referring to link below:
https://www.intel.com/content/www/us/en/support/articles/000058073/programs/resource-and-documentation-center.html
Hope this clarifies.
Sazzy_Intel
Ilpo
This datasheet is very sparse. I would need a document that describes the controller registers in detail. Maybe a programming manual or similar? I could not find this kind of document in Resource & Documentation Center.
BR,
Ilpo
Simon-Intel
Hi Ilpo,
Thank you for your response.
Kindly confirm if you have an Intel Developer Zone Premier account as some documents in Resource & Documentation Center can be viewed only under and active CNDA.
For more information, you may refer to the below article.
Simon
intel.com/vroc
Ilpo
Hi Simon,
 I do have a premier account.
BR,
Ilpo
IntelSupport
Community Manager
Hi Ilpo,
Greetings from Intel!
Please log in with your premium account and search for the document using the DOC ID.
If you need any assistance, feel free to reach out.
Akshaya
Intel.com/vroc
Ilpo
What is the "DOC ID" for the document that contains detailed register descriptions for I226?
BR,
Ilpo
IntelSupport
Community Manager
Hi Ilpo,
We will look into the details for you and provide an update as soon as possible. We appreciate your patience.
Akshaya
Intel.com/vroc
IntelSupport
Community Manager
Hi Ilpo,
Thank you for your patience.
The document you are looking for can only be shared via IPS, and you will need to have an active NDA in place to access it.
Please raise an IPS case for further assistance regarding your query. You can refer to the articles below for more information on how to proceed:
Akshaya
Intel.com/vroc
Ilpo
My request for Premier Support was declined..
Meanwhile, not very happy with Intel, was looking for some clues in FreeBSD kernel sources and found this:
#define IGC_I225_PHPM_DIS_100_D3 0x0200 /* Disable 100M in D3 */
WOL problem is solved by clearing this bit in PHY power management register.
BR,
Ilpo
IntelSupport
Community Manager
Hi Ilpo,
Could you kindly provide more details regarding the reason mentioned for the decline of your Premier Support request? Based on this information, we can further investigate and assist you accordingly.
Akshaya
Intel.com/vroc
Ilpo
I think the reason was that my email address is from corporation global IT but the company name is the subsidiary company I work for.
Apparently someone thought I was trying to register with my personal address which is not the case.
BR,
Ilpo
Sachinks
Hello Ilpo,
Thank you for your reply.
We are sorry to hear that your request for premier support was declined.
Since this request is directly handled by the premier support team, only they will be able to grant the access unfortunately.
In this case, we request you to contact your intel representative so that they can check this from their end.
Also, we see that you have mentioned your were looking for some clues in FreeBSD kernel sources and the WOL problem is solved by clearing this bit in PHY power management register.
Kindly let us know if you need any additional assistance regarding this so that we can check it.
Sachin KS
intel.com/vroc
pujeeth
Hello IIpo,
Greetings!
Kindly let us know if we can proceed with closing this case.
Pujeeth
intel.com/vroc
pujeeth
Hello IIpo,
Greetings!
We will proceed to close this case. If you find that you still required assistance, we kindly request you to respond to the case. This will allow us to either reopen the current case or initiate a new one.
Pujeeth
Intel Customer Support
intel.com/VROC
