Ethernet Products
5821 Discussions
I350 EEPROM setting PCIe Link Speed
SWang9
I want to change I350 PCIe link speed to Gen1 from EEPROM but I don't know address, who can help~
Hi Samuel_123,
Thank you for the post. I will check how this can be done and will update you.
Rgds,
wb
SWang9
OK, wait for your update~
Hi Samuel_123,
Good day. As this is a Gen2 card, the process is to disable Gen2 PCIe then this should put it back to Gen1 to function. So you can try setting "Disable PCIe Gen 2" field", bit "8" to value "1b",
Hope this helps.
rgds,
wb
SWang9
Hi Wb,
Thanks for your reply, but my question is where "PCIe Link configuration register address & data" mapping to "I350_C.eep" location? Sorry description not good cause your confuse.
Samuel
Hi Samuel_123,
Thank you for the clarification. Let me check on this.
rgds,
wb
HI Samuel,
Further checking, if you are having issue in editing the eeprom, we will have to escalate but this might take some time, please update me if you are OK with possible long timeline. Thanks.
rgds,
wb
SWang9
Hi Wb,
OK, I can wait, but please do it Asap, thanks.
rgds,
Samuel
Hi Samuel,
Thanks for the reply. I will update you once there is any feedback.
Rgds,
wb
Hi Samuel,
Good day. Just to clarify further, we will not be providing you the instruction or steps on how to edit eeprom setting, what we will be providing is a custom set. Please confirm if this is OK from your end.
wb
SWang9
Hi Wb,
OK, I just want to know where "PCIe Link configuration register address & data" mapping to "I350_C.eep" location.
Rgds,
Samuel
Hi Samuel,
Thank you for the confirmation.
rgds,
wb
Hi Samuel,
Can you provide the eep file shown in screenshot?
wb
SWang9
Hi Wb,
Attached eep file for you.
rgds.
Samuel
Hi Samuel,
Thanks for the file. We will further check on this.
rgds,
wb
Hi Samuel,
I sent a private message to you. Please check.
wb
Hi Samuel,
Please let us know if still need additional assistance regarding i350.
thanks,
Vince
AmosChien
I have the same question, could you also send me the answer?
