Windows version: Windows 10 Enterprise Version: 21H2
OS Build: 19044.2075
Intel Wired: 27.6
Network card: Intel I350-T2V2
Driver version: 12.18.13.0
Driver date: 2021-12-14
Hi , I am facing bluescreen on I350-T2 when try to disable Interrupt Moderation or any other settings with the code BUGCODE NDIS DRIVER. On a second identical PC i have with the second card with Windows 10 Enterprise build 1809 and latest drivers I do not have this problem or blue screen. No the card is not malfunctioning i have already done the changeover with the second identical PC I have. Regards, Chris
Edit
I post a new message because on previous post I do not know I couldn't reply for unknown reason.
The driver I have downloaded is this:
The wired driver only.
The more intresting is that when I disable everything from the drivers (interrupt moderation, offloading,side scaling,etc.) it performs way better but the blue screen are then not so often when the default parameters are installed.
Chris
