Ethernet Products
5736 Discussions
Ice dpdk and flow control
kharo22
Hello
it seems we cannot use the api rte_eth_dev_flow_ctrl_set with nic driven by ice (unlikely ixgbe)
How can we disable the rx flow control (on E810 for example) please ?
is it the same  command line option acl=off ? if yes which api to call to do it inside a C program please
thank you
BR
Karim
Poojitha
Hi kharo22
Greetings for the day!
We are following up to check if you were able to find the information we requested. Kindly confirm at your earliest convenience, so that we can continue assisting you in resolving this matter.
We appreciate your understanding!
Poojitha
Poojitha
Hi kharo22,
Thank you for posting in the Intel Community. We sincerely apologize for the delay in our response. We have received your concern and would like to assure you that assisting you is our top priority.
Could you kindly let us know if the issue has been resolved, or if you require further assistance from us? Your prompt response will greatly help us in diagnosing and resolving the issue as quickly as possible.
We appreciate your patience and understanding, and we look forward to hearing from you soon.
Poojitha
Poojitha
Hi kharo22,
Could you please confirm if your query is related to the use of Intel products and solutions in regard to military, intelligence, nuclear/biochemical, defense, or space (MINDS) items?
Poojitha
Poojitha
Hi kharo22,
Poojitha
kharo22
Hello
I did not resolve my issue so yes please if you could help me for that point.
Thank you
BR
kharo22
Poojitha
Hi kharo22,
Poojitha
kharo22
I confirm it is not related to any mentionned area (military, intelligence, nuclear/biochemical, defense, or space) , it is only for network  purpose.
MACM
Hi kharo22
Greetings of the day.
Thank you for your response.
Please go through the below link and let us know if you have any questions.
Advanced Driver Settings for Intel® Ethernet 10 Gigabit Server...
Mohammed Ali CM
Intel Customer Support
Poojitha
Hi kharo22
Poojitha
Poojitha
Hi kharo22
Poojitha
Poojitha
Hi kharo22
Poojitha
kharo22
Hi Poojitha
The link you gave is a general purpose, it is not related to dpdk.
My question is clearly will E810 be able to be use within dpdk API rte_eth_dev_flow_ctrl_set .
Thank you.
Poojitha
Hi kharo22,
Kindly find the requested Intel® Ethernet E810 Data Plane Development Kit (DPDK) Configuration Guides with complete information below:
https://www.intel.com/content/www/us/en/support/articles/000098430/ethernet-products.html
If you have any questions or doubts, please reach out to us. We are happy to assist you!
Poojitha N
Poojitha
Hi kharo22
Poojitha
Poojitha
Hi kharo22
Poojitha
Poojitha
Hi kharo22
Poojitha
