Ethernet Products
4623 Discussions
Install PROSet from a network share
SJean
I'm trying to install Intel PROSet with MDT. So the install folder is a remote share (\\MDT\DeploymentShare$\Applications\Intel).
With the previous version, I used the msi (PROSETDX.msi) but with the new version it's impossible because there is a check to force the use of DxSetup.exe.
But DxSetup crash at the end of the installation.
How I can install this tool with MDT ?
Stephane.
VincentT_T_Intel
Hi Stephane,have you tried using msiexec.exe instead? here's a reference from Intel site:
http://www.intel.com/support/network/sb/cs-016040.htm http://www.intel.com/support/network/sb/cs-016040.htm
hope this help.
