Ethernet Products
5704 Discussions
Intel 82579v - Code 10 - media disconnected
After long shutdown and then power up ( eg. Power up in morning ) 82579v adapter shows Windows driver code 10 - with media disconnected status in ipconfig.
Shutdown and restart does not fix. Hard power off while machine running, wait 60 seconds and power on usually fix. Bio reset default also fix.
Problem re-occurs if machine is shutdown and powered off for a few hours.
It is not cabling or router since problem is resolved by one of the above power cycle steps.
Configuration:
Motherboard: Asus P8Z77-V Pro
Bios: Asus 2104 ( latest )
OS: Windows 10-x64
Network Driver: Intel 12.5.31.4 / ProSet 21.1.30.0
Applied NVRam update ( 82579VSKU ) adapter is now 82579V - no longer bounces to LM.
Tried:
Older BIOS
Microsoft Windows 10 Driver
Problem appears similar to:
/message/264820# 264820 https://communities.intel.com/message/264820
/thread/110194 https://communities.intel.com/thread/110194
Hi Rman'1900,
Thanks for the info. I will try check for the meantime, please also further check with Asus* as this is onboard NIC if they have any information to share.
wb
Hi Rman'1900,
Further checking, you need to contact your system manufacturer regarding this issue.
Rgds,
wb
RPalm3
I partly solved using the command dos BOOTUTILW64E.EXE -DEFCFG –ALL.
On reboot, changing the driver manually to 82579LM, the card starts working again for a few days. Subsequently, when the PC is switched off for a few days, the card mysteriously changes drivers and stops.
Then the procedure again and operation resumes
