Ethernet Products
5306 Discussions
Intel Converged X540-T2 - Not working Proxmox - Debian
crazyhorse1
Hi I have this card PCI-E Intel 540-AT2 adapter in a supermicro sys-4028.
The card is recognized by the bios but no lights in proxmox. It's not the cable or the switch (c3850) as I have tested with other cables and other switches.
I have also updated the driver with the one provided by Intel (https://ark.intel.com/content/www/us/en/ark/products/58954/intel-ethernet-converged-network-adapter-x540-t2.html) ... no results unfortunately:
ethtool -i enp10s0f0
root@S3ai:~# ethtool -i enp10s0f0
driver: ixgbe
version: 5.21.5
firmware-version: 0x80000389
expansion-rom-version:
bus-info: 0000:0a:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
root@S3ai:~# ethtool -i enp10s0f1
driver: ixgbe
version: 5.21.5
bus-info: 0000:0a:00.1
supports-test: yes
root@S3ai:~#
I have four interfaces:
root@S3ai:~# lshw -class network -businfo
Bus info Device Class Description
pci@0000:0a:00.0 enp10s0f0 network Ethernet Controller 10-Gigabit X540-AT2
pci@0000:0a:00.1 enp10s0f1 network Ethernet Controller 10-Gigabit X540-AT2
pci@0000:81:00.0 enp129s0f0 network Ethernet Controller 10-Gigabit X540-AT2
pci@0000:81:00.1 enp129s0f1 network Ethernet Controller 10-Gigabit X540-AT2
enp129s0f0 and enp129s0f1 are working in a bond with the ethernet card provided natively with the server. Bond seems to be slower 10G instead of 20G but working.
enp10s0f0 and enp10s0f1 do not work and it says NO-CARRIER
ip a
root@S3ai:~# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enp10s0f0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether a0:36:9f:1a:45:84 brd ff:ff:ff:ff:ff:ff
3: enp10s0f1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether a0:36:9f:1a:45:86 brd ff:ff:ff:ff:ff:ff
4: enp129s0f0: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc mq master bond0 state UP group default qlen 1000
link/ether 0c:c4:7a:eb:35:a2 brd ff:ff:ff:ff:ff:ff
5: enp129s0f1: <BROADCAST,MULTICAST,SLAVE,UP,LOWER_UP> mtu 1500 qdisc mq master bond0 state UP group default qlen 1000
link/ether 0c:c4:7a:eb:35:a2 brd ff:ff:ff:ff:ff:ff permaddr 0c:c4:7a:eb:35:a3
6: bond0: <BROADCAST,MULTICAST,MASTER,UP,LOWER_UP> mtu 1500 qdisc noqueue master vmbr0 state UP group default qlen 1000
7: bond0.1001@bond0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 10.30.3.3/24 scope global bond0.1001
inet6 fe80::ec4:7aff:feeb:35a2/64 scope link
8: vmbr0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 10.30.1.3/24 scope global vmbr0
9: bond0.1000@bond0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue master vmbr1 state UP group default qlen 1000
10: vmbr1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
/etc/network/interfaces
root@S3ai:~# cat /etc/network/interfaces
# network interface settings; autogenerated
# Please do NOT modify this file directly, unless you know what
# you're doing.
# If you want to manage parts of the network configuration manually,
# please utilize the 'source' or 'source-directory' directives to do
# so.
# PVE will preserve these directives, but will NOT read its network
# configuration from sourced files, so do not attempt to move any of
# the PVE managed interfaces into external files!
auto lo
iface lo inet loopback
auto enp129s0f0
iface enp129s0f0 inet manual
#10G
auto enp129s0f1
iface enp129s0f1 inet manual
#10G
auto enp10s0f0
iface enp10s0f0 inet manual
#10G network card not connected
auto enp10s0f1
iface enp10s0f1 inet manual
auto bond0
iface bond0 inet manual
bond-slaves enp129s0f0 enp129s0f1
bond-miimon 100
bond-mode 802.3ad
bond-xmit-hash-policy layer3+4
bond-downdelay 200
bond-updelay 200
#10G aggregation
auto bond0.1000
iface bond0.1000 inet manual
#cluster public network - 10.30.2.3/24
auto bond0.1001
iface bond0.1001 inet static
address 10.30.3.3/24
#cluster private network
auto vmbr0
iface vmbr0 inet static
address 10.30.1.3/24
gateway 10.30.1.1
bridge-ports bond0
bridge-stp off
bridge-fd 0
#PX mgmt
auto vmbr1
iface vmbr1 inet manual
bridge-ports bond0.1000
bridge-stp off
bridge-fd 0
bridge-vlan-aware yes
bridge-vids 2-4094
source /etc/network/interfaces.d/*
log
[ 2.248907] ixgbe: loading out-of-tree module taints kernel.
[ 2.249219] ixgbe: module verification failed: signature and/or required key missing - tainting kernel
[ 2.282472] ixgbe 0000:0a:00.0 0000:0a:00.0 (uninitialized): ixgbe_check_options: FCoE Offload feature enabled
[ 2.449199] ixgbe 0000:0a:00.0: Multiqueue Enabled: Rx Queue count = 63, Tx Queue count = 63 XDP Queue count = 0
[ 2.497404] ixgbe 0000:0a:00.0: 16.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x4 link at 0000:00:1c.0 (capable of 32.000 Gb/s with 5.0 GT/s PCIe x8 link)
[ 2.530923] ixgbe 0000:0a:00.0 eth0: MAC: 3, PHY: 3, PBA No: G45270-003
[ 2.531217] ixgbe 0000:0a:00.0: a0:36:9f:1a:45:84
[ 2.531453] ixgbe 0000:0a:00.0 eth0: Enabled Features: RxQ: 63 TxQ: 63 FdirHash
[ 2.537877] ixgbe 0000:0a:00.0 eth0: Intel(R) 10 Gigabit Network Connection
[ 2.543470] ixgbe 0000:0a:00.1 0000:0a:00.1 (uninitialized): ixgbe_check_options: FCoE Offload feature enabled
[ 2.715932] ixgbe 0000:0a:00.1: Multiqueue Enabled: Rx Queue count = 63, Tx Queue count = 63 XDP Queue count = 0
[ 2.765913] ixgbe 0000:0a:00.1: 16.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x4 link at 0000:00:1c.0 (capable of 32.000 Gb/s with 5.0 GT/s PCIe x8 link)
[ 2.798985] ixgbe 0000:0a:00.1 eth1: MAC: 3, PHY: 3, PBA No: G45270-003
[ 2.799231] ixgbe 0000:0a:00.1: a0:36:9f:1a:45:86
[ 2.799472] ixgbe 0000:0a:00.1 eth1: Enabled Features: RxQ: 63 TxQ: 63 FdirHash
[ 2.805854] ixgbe 0000:0a:00.1 eth1: Intel(R) 10 Gigabit Network Connection
[ 2.810660] ixgbe 0000:81:00.0 0000:81:00.0 (uninitialized): ixgbe_check_options: FCoE Offload feature enabled
[ 2.975917] ixgbe 0000:81:00.0: Multiqueue Enabled: Rx Queue count = 63, Tx Queue count = 63 XDP Queue count = 0
[ 3.025016] ixgbe 0000:81:00.0: 16.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x4 link at 0000:80:00.0 (capable of 32.000 Gb/s with 5.0 GT/s PCIe x8 link)
[ 3.033752] ixgbe 0000:81:00.0 eth2: MAC: 3, PHY: 3, PBA No: 030C00-000
[ 3.034134] ixgbe 0000:81:00.0: 0c:c4:7a:eb:35:a2
[ 3.034405] ixgbe 0000:81:00.0 eth2: Enabled Features: RxQ: 63 TxQ: 63 FdirHash
[ 3.040850] ixgbe 0000:81:00.0 eth2: Intel(R) 10 Gigabit Network Connection
[ 3.044725] ixgbe 0000:81:00.1 0000:81:00.1 (uninitialized): ixgbe_check_options: FCoE Offload feature enabled
[ 3.210429] ixgbe 0000:81:00.1: Multiqueue Enabled: Rx Queue count = 63, Tx Queue count = 63 XDP Queue count = 0
[ 3.260919] ixgbe 0000:81:00.1: 16.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x4 link at 0000:80:00.0 (capable of 32.000 Gb/s with 5.0 GT/s PCIe x8 link)
[ 3.269678] ixgbe 0000:81:00.1 eth3: MAC: 3, PHY: 3, PBA No: 030C00-000
[ 3.270207] ixgbe 0000:81:00.1: 0c:c4:7a:eb:35:a3
[ 3.270500] ixgbe 0000:81:00.1 eth3: Enabled Features: RxQ: 63 TxQ: 63 FdirHash
[ 3.276929] ixgbe 0000:81:00.1 eth3: Intel(R) 10 Gigabit Network Connection
[ 3.292756] ixgbe 0000:0a:00.0 enp10s0f0: renamed from eth0
[ 3.299150] ixgbe 0000:0a:00.1 enp10s0f1: renamed from eth1
[ 3.333744] ixgbe 0000:81:00.0 enp129s0f0: renamed from eth2
[ 3.347071] ixgbe 0000:81:00.1 enp129s0f1: renamed from eth3
[ 9.388859] ixgbe 0000:0a:00.0: registered PHC device on enp10s0f0
[ 9.779075] ixgbe 0000:0a:00.1: registered PHC device on enp10s0f1
[ 10.185021] ixgbe 0000:81:00.0: registered PHC device on enp129s0f0
[ 10.555598] ixgbe 0000:81:00.1: registered PHC device on enp129s0f1
[ 10.675605] ixgbe 0000:81:00.0 enp129s0f0: entered allmulticast mode
[ 10.677409] ixgbe 0000:81:00.1 enp129s0f1: entered allmulticast mode
[ 10.680855] ixgbe 0000:81:00.0 enp129s0f0: entered promiscuous mode
[ 10.682723] ixgbe 0000:81:00.1 enp129s0f1: entered promiscuous mode
[ 16.452049] ixgbe 0000:81:00.0 enp129s0f0: NIC Link is Up 10 Gbps, Flow Control: None
[ 16.836114] ixgbe 0000:81:00.1 enp129s0f1: NIC Link is Up 10 Gbps, Flow Control: None
