- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
Hello Intel Community,
We are seeing an intermittent physical link bring‑up failure on an Intel E810 NIC when using PF passthrough (PFPT) to a VM. After reboot (host or VM), the passed‑through PF sometimes fails to establish link.
Environment
- Server: Dell PowerEdge R640
- NIC: Intel Ethernet Controller E810-C for QSPF [8086:1592] (Dell OEM, dual‑port)
- NVM/Firmware: 4.20
- Host ICE driver: 1.11.14
- Guest ICE driver: 1.6.4
- DDP: 1.3.26 and 1.3.53
- DPDK: 24.11.1
- Mode: PF passthrough
- Compute Host OS:
- Host OS: SUSE Linux and kernel version: 5.3.18
- Guest OS: Linux - 4.19
Observed Behaviour
- After reboot, the PF in the VM fails to establish physical link.
- The peer switch port also goes down, confirming this is not just a software reporting issue.
- After a VM reboot, port availability is inconsistent; occasionally both ports come up, but often only one or neither initializes.
- No kernel dmesg errors are seen.
Could you please advise on:
- Known limitations of Intel E810 in PF passthrough mode.
- Known issues in NVM 4.20 related to EMP behaviour, global reset, or dual‑port interactions.
- Recommended firmware and driver combinations for PFPT (DPDK‑based deployments).
- Any potential software-level workarounds to mitigate compatibility issues or performance bottlenecks without changing the underlying firmware/driver?
Thanks in advance for your guidance.
Susmitha
Susmitha
Link copiado
3 Respostas
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Susmitha,
Greetings for the day!
Thanks for contacting Intel Customer Support with your query:
Kindly share the complete model of the NIC card and the also the clear picture of the card with serial number and part number visible.
Jerome
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Jerome,
Thank you for your response.
I will share the clear pictures of the NIC card via email, rather than posting them on the public forum.
Kindly let me know if there is a specific email address I should send them to.
Looking forward to your confirmation.
Susmitha
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Susmitha,
Thank you for your response. We will contact through your Email for further details.
Pavithra_Intel
Responder
Opções do tópico
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
