Ethernet Products
5658 Discusiones
Intel Etherner i219-V driver for Windows 8.1
AlexVor
Principiante
3.530 Vistas
Hello! I purchased a monoblock with an integrated network adapter Intel (14) i219-V. There was a need to install Windows 8.1 on a monoblock. After installing Windows 8.1, the network adapter driver was not automatically installed. In device manager ID 8086&DEV_15FA&SUBSYS_00008086&REV_11. Several times I downloaded driver sets for Intel (14) i219-V suitable, judging by the description, for Windows 8.1. None of the downloads worked. Previously downloaded a set of drivers from this link https://www.intel.com/content/www/us/en/products/sku/82186/intel-ethernet-connection-i219v/downloads.html . They didn't fit.
I would be grateful if experienced users post a link to a suitable set of drivers for the network adapter 8086&DEV_15FA&SUBSYS_00008086&REV_11.
0 kudos
5 Respuestas
Irwan_Intel
Moderador
3.501 Vistas
Hi AlexVor,
The link you've attached is the correct link for the latest Intel driver version.
https://www.intel.com/content/www/us/en/download/17479/intel-network-adapter-driver-for-windows-8-1.html
However on the release notes v28.0, the drivers has ended support for Microsoft Windows 8.1
https://downloadmirror.intel.com/772076/Release_Notes_28.0.pdf (page 4)
I could suggest version 25.2 which supported on Windows 8.1
https://www.intel.com/content/www/us/en/download/17479/29941/intel-network-adapter-driver-for-windows-8-1.html
And try with clean driver installation for the monoblock.
Instructions: https://www.intel.com/content/www/us/en/support/articles/000058304/ethernet-products.html
Note: If you're using OEM Ethernet, the driver or software for your Intel component might have been changed or replaced by the computer manufacturer. We recommend you work with your OEM manufacturer before installing our driver so you don’t lose features or customizations.
Please let me know if you have further questions or concern.
Irwan
Intel Customer Support
AlexVor
Principiante
3.483 Vistas
Hi Irwan!
Thanks for the help. Unfortunately, the steps you described did not help install the driver. I did a clean install but still got a message saying the intel adapter was not found. The inf files from the drivers folder do not contain the PCI\VEN_8086&DEV_15FA&SUBSYS_00008086&REV_11 device in the "DisplayName" blocks. Maybe there is a driver specifically for this particular device? In addition to version 25.1, I have already tried installing almost all versions of drivers for Intel i219-V.
Irwan_Intel
Moderador
3.431 Vistas
Hi AlexVor,
May I know your monoblock model? Intel provides generic drivers that may not be compatible and maybe the reason its could not found your NIC card.
Since this is integrated NIC from OEM manufacturer, I would suggest you to check with the computer manufacturer for the drivers compatibility with your system.
Irwan_Intel
Irwan_Intel
Moderador
3.394 Vistas
Hi AlexVor,
We have not heard from you since our last communication and we would like to know if you need further assistance on the case.
We will be looking forward to your reply in case that you need further assistance.
Irwan_Intel
Intel® Customer Support
Irwan_Intel
Moderador
3.352 Vistas
Hi AlexVor,
We have not heard from you since our last communication therefore we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Irwan_Intel
Responder
