Ethernet Products
5762 Discussions
Intel I211-AT gigabit unable to reach more than 100mbps
Coruen
yesterday optical fiber was installed at my apartment and through Wi-Fi I am able to reach the full 500mbps on my phone and laptop. The issue is that on my PC I can't reach more than 100mbps through ethernet.
I have an Asus ROG Strix B-350-f (Intel I211 Gigabit LAN controller). The cable is Cat5e, the ethernet is plugged into a 2.5g port. The operating system is windows 10.
Steps I took:
- reconnected the LAN cable from the PC to my laptop -> full 500mbps speed (windows 11 laptop)
- fiddled with speed & duplex (tried auto-negotiation, tried full duplex) -> no change
- resetted the network drivers installed the newest one (3 times, I have also tried older drivers)
- disabled energy-efficient ethernet and moderation
- flushed DNS
- plugged into different ports
Coruen
Additional info:
the motherboard is 450-f (NOT 350-f)
I have found the attached screenshot in the manual for the motherboard. The activity link LED on my pc blinks orange the speed LED is constantly orange.
Faez_Intel
Hi Coruen,
Good day and thank you for contacting Intel Community Support.
Please kindly help to provide the SSU logs for us to analyze further on this issue. Refer to the link below on how to gather the logs:
Additionally, what is the speed you are mostly seeing on your PC when connected to the LAN? Also, may I know if you are using the drivers provided by the OEM or from Intel generic drivers?
Thank you,
Faez_Intel
Coruen
thank you for the reply. I have uploaded the log below.
The usual speed is 100mbps. Drivers: I've downloaded and installed the newest Intel one specific for my MB. I've also installed PROset utility.
Thank you and have a nice day,
David
Faez_Intel
HI David,
Good day. Apologies for the delayed response.
Thank you for the logs provided. Based on the logs we can see that the current driver version is at 12.18.16.0.
Based on the OEM website for the motherboard model, the latest driver available for this motherboard is driver version 12.15.184.1
For this matter, I highly advise for your end to use the driver provided by the OEM itself. This is due to the drivers from the OEM is customized to run accordingly on your motherboard.
Please kindly use the latest driver for your motherboard model as per the link below.
https://rog.asus.com/motherboards/rog-strix/rog-strix-b450-f-gaming-model/helpdesk_download/
Faez_Intel
Faez_Intel
Hi David,
Good day. This is a follow up on the thread. Please let us know if you have any other questions and we will assist you accordingly.
Faez_Intel
Coruen
Hi Faez. I updated the driver to the appropriate version but nothing new happened.
Faez_Intel
Hi David,
Good day and noted on that. Can you help to gather the latest SSU logs for us to analyze further on this issue? Refer to the link below on how to gather the logs:
Let us know if you have any other questions
Faez_Intel
Faez_Intel
Hi David,
Good day. This is a follow up on the thread. Please kindly provide the SSU logs for us to analyze further on this issue. Do let us know if you have any other questions.
Faez_Intel
Faez_Intel
Hello David,
I hope you're having a wonderful day. I am just sending a follow up to check if you still have questions or clarifications. As for now, we will be closing your thread.
If you want to continue support, please reply to this community thread and we will reopen your case or create a new one so that we can continue to support you.
Faez_Intel
Coruen
Hello. I still require assistance. In my previous message are the logs with the correct driver version.
Coruen
Hi Faez,
sorry I didn't respond, I was out of the country. I am attaching the logs
Good day to you,
-Coruen
