Ethernet Products
5675 Discussions
Intel I211 Gigabit Network Connection disabled (code 22) - Windows 10
Kiara
Hello
This morning I turned on my desktop pc and I noticed that my connection wasn’t working. It was working fine yesterday.
Intel I211 Gigabit Network Connection keep disabling itself. I’ve already tried different fixes, such as:
- Tried to enable it again from “internet connections”, it disabled itself
- Tried to enable it from Device Manager, it disabled itself
- Reinstalling the drivers from Device Manager (windows says that the best driver is already installed)
- ipconfigr release/renew/dns flush via the command line
- Reset netsh via the command line (e.g. netsh winsock reset)
My setup is:
Windows 10 pro (22H2 version, last update was KB5040427 and KB5041019 for .net framework)
Gigabyte Z170X Designare motherboard
ethernet cable
Can you help me fix this?
Is this an update/driver problem or I can fix this buying a new network card?
Thank you
Poojitha
Hi Kiara,
Greetings for the day!
Thank you for posting in the Intel Community. We sincerely apologize for the delay in our response. We have received your concern and would like to assure you that assisting you is our top priority.
Could you kindly let us know if the issue has been resolved, or if you require further assistance from us? Your prompt response will greatly help us in diagnosing and resolving the issue as quickly as possible.
We appreciate your patience and understanding, and we look forward to hearing from you soon.
Poojitha
Poojitha
Hi Kiara,
We are following up to check if you were able to find the information we requested. Kindly confirm at your earliest convenience, so that we can continue assisting you in resolving this matter.
We appreciate your understanding!
Poojitha
Poojitha
Hi Kiara,
Poojitha
