I need driver for Intel® I225-V 2.5Gb Ethernet, because currently i cannot connect my computer to internet. Please ASAP!
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Thanks for reply. It is all not so easy without internet, but with pendrive i will carry the mentioned intel utility.
U.I, but i just simply need an I225-V driver, because i cannot find nowhere for 8.1 neither for Windows 7.
complete driver pack, tested with w8.1
https://downloadcenter.intel.com/download/22283/Intel-Ethernet-Adapter-Complete-Driver-Pack
My motherboard is ASUS ROG STRIX B550-I GAMING
equipped with,
-Intel® I225-V 2.5Gb Ethernet
and with
-Intel® Wi-Fi 6 AX200
And everything works fine, from usb, storage, graphics, expect i don’t have internet. Because my unluck both of the internet adapters are from Intel. And now i have to throw away my whole installation work both at hardware and software side and look for a different motherboard. Please give driver, before i taking apart everything, i need to use my computer.
Hello ,
I just want to add that as per the list of validated OS for Ethernet cards. Intel® I225-V is not validated for Windows 8.1.
Kindly check the link below:
If you are using on-board or embedded Intel® I225-V and the board is validated or compatible with Windows 8.1.
The board manufacturer should provide the appropriate driver for all of the embedded components on the board including the Intel® I225-V. So it is best to Contact Asus to check if the board supports Windows 8.1 and if yes, to download the driver for onboard Intel® I225-V.
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days.
Thank you.
Michael L.
Intel Customer Support Technicians
Hello Rdack,
I just want to check if you already tried to contact the board manufacturer for further assistance on the driver.
Thank you.
Michael L.
Hello Rdack,
I am just sending another follow up on the information that I requested.
If you need further assistance, please post a new question.
Thank you.
Michael L.
