Ethernet Products
5744 Discussions
Intel I225-V driver and connection problem (MSI z690 carbon WiFi ) ver.2 with solution
AleksandrWawa
previously
problem with Ethernet card Intel i225-V, connection was not recognized.
Computer: MatherBoard MSI z690 carbon WiFi (MS-7D30 ver 1.1) BIOS E7D30IMS.1F0, processor 12700К, embed Ethernet card  Intel i225-V.
System: Windows 10 x64 and Windows Server 2019 x64
1gigabit switch TP-Link TL-SG 1024DE v2.0
3 meter Ethernet cable no-name, but working on 1Gb on another computer in the same network.
Testing with different version of windows drivers have no successes.
Middle solution: Using 3 meter Ethernet cable no-name. It was possible to start MANUAL connection on 100Mbit. Automatic negotiation of speed failed.
Solution: Use brand new 5 meter CAT6 cable. Connection recognized on 1Gb. (limited by switch)
Conclusion: Ethernet card Intel i225-V is EXTREMELY SENSITIVE  to quality of Ethernet cables. Use CAT6 or higher.
Thank You.
Irwan_Intel
Hello AleksandrWawa
Thank you for providing detailed information regarding the issue with the Intel i225-V Ethernet card.
We appreciate your feedback regarding your findings.
Irwan_Intel
