Hi,i have the following issue. i am using a workstation equipped with Intel X550-T2 card and connected both 10Gbase-T ports with a cat7 cable to switch-port 27/28. switch-port 27/28 are also 10Gbase-T capable.
only one port on the intel card will connect at full speed (10Gbps). the second port will run with 1Gbps. I tried these things:
- build up a lan-team on workstation-side in windows server 2012
- forced card- and switch-ports to 10Gbase
- build a aggregation with both switch-ports
nothing really helped. is there a compatibility problem between card and switch ?
i tried also to active and deactivate stp. i dont understand why only one port run with full speed.
i got a supermicro-mainboard based server in my office as well, two intel x550 onboard ports and the same problem occur. one port is at full speed the second port is at 100Mbps.
- « Previous
- Next »
Hi Michael, please let us know if you still need assistance regarding your issue.
regards,
Vince
- « Previous
- Next »
