Ethernet Products
5734 Discussions
Intel X710-DA4 connection problem
YWang91
I recently purchased an intel x710-da4 and a usrp x300 with (ettus's wire https://www.ettus.com/product/details/ECARD-KIT https://www.ettus.com/product/details/ECARD-KIT ). But the problem is that the ethernet could not be connectted between the two devices.
sudo ethtool -m enp2s0f3
Identifier : 0x03 (SFP)
Extended identifier : 0x04 (GBIC/SFP defined by 2-wire interface ID)
Connector : 0x21 (Copper pigtail)
Transceiver codes : 0x01 0x00 0x00 0x04 0x41 0x84 0x80 0xd5
Transceiver type : Infiniband: 1X Copper Passive
Transceiver type : Ethernet: 1000BASE-CX
Transceiver type : FC: short distance (S)
Transceiver type : FC: Electrical inter-enclosure (EL)
Transceiver type : FC: Electrical intra-enclosure (EL)
Transceiver type : FC: Copper Passive
Transceiver type : FC: Twin Axial Pair (TW)
Transceiver type : FC: 1200 MBytes/sec
Transceiver type : FC: 800 MBytes/sec
Transceiver type : FC: 400 MBytes/sec
Transceiver type : FC: 200 MBytes/sec
Transceiver type : FC: 100 MBytes/sec
Encoding : 0x00 (unspecified)
BR, Nominal : 12000MBd
Rate identifier : 0x00 (unspecified)
Length (SMF,km) : 0km
Length (SMF) : 0m
Length (50um) : 0m
Length (62.5um) : 0m
Length (Copper) : 3m
Length (OM3) : 0m
Passive Cu cmplnce. : 0x00 (unspecified) [SFF-8472 rev10.4 only]
Vendor name : Molex Inc.
Vendor OUI : 00:09:3a
Vendor PN : 74752-1301
Vendor rev :
Option values : 0x00 0x00
BR margin, max : 0%
BR margin, min : 0%
Vendor SN : 627540545
Date code : 161001
IOUtil v1.30.25.6 - Intel(R) Network IO Mode Enable/Disable Utility
Copyright (C) 2017 by Intel (R) Corporation. All rights reserved.
Usage:
Run with no arguments to list adapters and usage.
/NIC=X Adapter to modify
/ALL Modify all adapters
/E Enable IO mode
/D Disable IO mode
NIC B/D/F Ven-Dev MAC IO Branding string
1) 02/00/00 8086-1572 3CFDFEA6FA58 NA Intel(R) Ethernet Converged Network Ada
2) 02/00/01 8086-1572 3CFDFEA6FA59 NA Intel(R) Ethernet Converged Network Ada
3) 02/00/02 8086-1572 3CFDFEA6FA5A NA Intel(R) Ethernet Converged Network Ada
4) 02/00/03 8086-1572 3CFDFEA6FA5B NA Intel(R) Ethernet Converged Network Ada
5) 06/00/00 8086-1533 0CC47ADC0426 ENA Intel(R) I210 Gigabit Network Connectio
6) 07/00/00 8086-1533 0CC47ADC0427 ENA Intel(R) I210 Gigabit Network Connectio
5 and 6 is my original network card in supermicro.
YWang91
And using the IOutil, the result is:
Adapter 1: IO is not supported. No action.
Adapter 2: IO is not supported. No action.
Adapter 3: IO is not supported. No action.
Adapter 4: IO is not supported. No action.
Adapter 5: IO is enabled. Reboot is required.
Adapter 6: IO is enabled. Reboot is required.
All operations completed.
Adapter 1-4 is the intel X710 port. And I have tried to downgrade to 5.05. Still it did not work.
Hi Yuanhao.wang,
Thank you for posting in Wired Communities. The X710-DA4 used validated cable listed in our website below at
https://www.intel.com/content/www/us/en/support/articles/000007045/network-and-i-o/ethernet-products.html
The Ecard kit is not the supported cable connection. The USRP x300 is a special device, you may try to check with USRP support for compatible network card for the connection.
Please let me know if you need further clarification.
Sharon T
YWang91
Hi Sharon,
Thank you, and I will contact Ettus.
Another question is could I purchase X710 - T4, and use normal twisted-wire to get to the normal ethernet?
Best,
Hi Yuanhao.wang,
You are welcome. X710-T4 supports RJ45 cable, you may refer to the product specification at
https://ark.intel.com/products/93428/Intel-Ethernet-Converged-Network-Adapter-X710-T4 https://ark.intel.com/products/93428/Intel-Ethernet-Converged-Network-Adapter-X710-T4. Please use RJ45 Cat 6 or Cat 6A cable as stated in the link above.
You can also contact our resellers which you can find at http://locate.intel.com if you want to purchase the network adapter.
Hope the above information help.
Sharon T
