Ethernet Products
5707 Discussions
Intel X710 Quadport 10GB Direct Attach Interface only coming as 1 Gbps when using 10Gbps LC,LR Dell SFPs, Any idea how to solve this?
Pakito
I have a Dell R740 Server fitted with 7 x Intel X710 Quadport 10 Gb cards, when we connect a Dell 10 Gb SFP+ LR,LC the cards only work at 1 Gb, but when we use 10 G Dell SFP+ SR, they work at 10 G , I also have tried with Dell 10G SFP SR and it seems work fine.
Initially, I thought the issue was with the SFPs but they seem to work on a Dell Ethernet 10G 4P X710/I350 rNDC card.
See below our R740 details environment:
OS:Ubuntu 16.04 LTS
Kernel: 4.4.0-87-generic # 110-Ubuntu SMP Tue Jul 18 12:55:35 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Intel driver: i40e
version: 2.4.10
firmware-version: 6.00 0x80003752 18.5.17
expansion-rom-version:
bus-info: 0000:3b:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
NVMupdate version:6.0
Intel X710 Firmware: 18.5.17
We have upgraded the server BIOS and iDRAC to the following releases:
BIOS:1.5.6
iDRAC:3.21.23.22
Francisco M.
Hello P@ick,
Thank you for posting in Intel Wired Ethernet Communities. If these are Intel retail X710 Adapters please see the following link for https://www.intel.sg/content/www/xa/en/support/articles/000007045/network-and-i-o/ethernet-products.html Supported SFP+ Modules. Please provide the output from lspci -nn | grep -i 'Ethernet Controller' so we can identify the adapter. Let us know if you have any questions.
Daniel D
Intel Customer Support
Pakito
19:00.0 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
19:00.1 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
3b:00.0 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
3b:00.1 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
3b:00.2 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
3b:00.3 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
5e:00.0 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
5e:00.1 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
5e:00.2 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
5e:00.3 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
60:00.0 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
60:00.1 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
60:00.2 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
60:00.3 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
86:00.0 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
86:00.1 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
86:00.2 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
86:00.3 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
88:00.0 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
88:00.1 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
88:00.2 Ethernet controller [0200]: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [8086:1572] (rev 01)
88:00.3 Etherne...
Hello P@ick,
Thank you for the outputs. To confirm if this is an Intel retail X710 adapter we would need the markings from the product label. The NVM and firmware version are from Dell, so this is most likely an OEM Dell version of the adapter. Please check with Dell for further support, as the supported SFP modules would be different for OEM Ethernet adapters. If you can provide the markings for further confirmation, or have any other questions please let us know.
Daniel D
Hello P@ick,
Please inform us if you were able to contact Dell about the supported SFP modules for the X710 adapter. If you have any questions please let us know.
Daniel D
Hello P@ick,
Let us know if you have any other questions. If you contacted Dell please continue to work with them.
Daniel D
