Ethernet Products
5868 Discussions
Intel X710 SR-IOV VF latency on small traffic
James_Lin
I using a X710-DA2  dual 10G port ,when I setup SR-IOV in Centos 7 ,I found VF is delay in response with small traffic ,ping command show like below :
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
From 10.10.10.20 icmp_seq=1 Destination Host Unreachable
From 10.10.10.20 icmp_seq=2 Destination Host Unreachable
From 10.10.10.20 icmp_seq=3 Destination Host Unreachable
From 10.10.10.20 icmp_seq=4 Destination Host Unreachable
64 bytes from 10.10.10.10: icmp_seq=5 ttl=64 time=2999 ms
64 bytes from 10.10.10.10: icmp_seq=6 ttl=64 time=2000 ms
64 bytes from 10.10.10.10: icmp_seq=7 ttl=64 time=1000 ms
64 bytes from 10.10.10.10: icmp_seq=8 ttl=64 time=0.320 ms
64 bytes from 10.10.10.10: icmp_seq=9 ttl=64 time=3000 ms
64 bytes from 10.10.10.10: icmp_seq=10 ttl=64 time=2000 ms
64 bytes from 10.10.10.10: icmp_seq=11 ttl=64 time=1000 ms
64 bytes from 10.10.10.10: icmp_seq=12 ttl=64 time=0.285 ms
64 bytes from 10.10.10.10: icmp_seq=13 ttl=64 time=3001 ms
64 bytes from 10.10.10.10: icmp_seq=14 ttl=64 time=2001 ms
64 bytes from 10.10.10.10: icmp_seq=15 ttl=64 time=1001 ms
64 bytes from 10.10.10.10: icmp_seq=16 ttl=64 time=0.338 ms
10.10.10.10 is VF address inside  Guest OS ,my i40e version in below :
filename:       /lib/modules/3.10.0-1160.15.2.el7.x86_64/updates/drivers/net/ethernet/intel/i40e/i40e.ko
version:        2.14.13
license:        GPL
description:    Intel(R) 40-10 Gigabit Ethernet Connection Network Driver
iavf :
filename:       /lib/modules/3.10.0-1160.el7.x86_64/kernel/drivers/net/ethernet/intel/iavf/iavf.ko.xz
version:        3.2.3-k
it is look like a slowstart behavior ,when I run ab to send more traffic to Guest ,the latency is gone .
rx_dropped in /sys/class/net/ens4f0/device/sriov/0/stats  is 0 .
still try to find out what happen ,it is look like some queue or cpu step-up behavior.
I been try with difference server (HPE DL380 Gen10 and C610),the behavior is same.
any input is welcome .many thanks .
