Ethernet Products
5861 Discussions
Intel boot agent
KGord
Acer Altos T11o F3 Server plus Intel server Adapter I340 F4
I have installed a Smoothwall Linux System but I am unable to boot from the harddisk due to PXE trying three times to boot from the internet then only option is to cycle back. The BIOS is version P11 and although previous BIOS versions provided a setting on the first page to turn off PXE, I can't find same on P11.
I believe BootUtil.exe -ALL -FD will disable all adapters, but I have no experience and have no idea how to run the app in my present circumstances.
Your advice would be much appreciated.
Kevin.
KGord
I installed Windows 8.1 and ran:
C:\>\Winx64\BOOTUTILW64E.EXE -ALL -FD
Intel(R) Ethernet Flash Firmware Utility
BootUtil version 1.5.94.2
Copyright (C) 2003-2015 Intel Corporation
Disabling boot ROM on port 1...Success
Disabling boot ROM on port 2...Success
Disabling boot ROM on port 3...Success
Disabling boot ROM on port 4...Success
Disabling boot ROM on port 5...
ERROR: Unsupported feature
Port Network Address Location Series WOL Flash Firmware Version
1 90E2BA8DE948 2:00.0 Gigabit YES FLASH Disabled
2 90E2BA8DE949 2:00.1 Gigabit N/A FLASH Disabled
3 90E2BA8DE94A 2:00.2 Gigabit N/A FLASH Disabled
4 90E2BA8DE94B 2:00.3 Gigabit N/A FLASH Disabled
5 408D5C60E8F6 5:00.0 Gigabit YES FLASH Not Present
BIOS version P11
PCI-E Slot Configuration
Launch PXE OpROM policy UEFI only
IPv4 PXE Support Disabled
IPv6 PXE Support Disabled
Are the above BIOS settings OK?
How can I turn off "Chasis was opened" message?
st4
New Contributor III
Hi Kg1,
The bootrom has been disabled. You can also try bootutil utility to disable the boot.
1) You can copy the bootutil.exe into a bootable USB drive, then boot from the USB drive.
2) Enter into DOS mode. Please refer to the extacted list of command here:
BOOTENABLE=DISABLED
Disables FCoE, iSCSI and PXE functionalities for legacy BIOS.
You may refer to this website for more information about the bootutil command http://www.intel.com/content/www/us/en/support/software/manageability-products/000005790.html Upgrade, Enable, or Disable Flash with the Intel® Ethernet Flash...
With regars to chassis was opened message, please check with Acer the system vendor.
rgds,
wb
