I was wondering if it is possible to change the MAC address on the i226 after it has been set?
We are able to program the i226 NVM image, but we can only set the MAC address once before it goes into a protected state. We program the NVM image, update the MAC, and then reboot and then we can no longer change the MAC address.
Is this intended behaviour? Is there a way to reset the i226 so we can change the MAC?
Hi Michael31,
Regarding your enquiry, since we may have a limited support on this issue, we will move this thread to our Intel Embedded Communities for the team to assist you. They will connect with you shortly.
Sazzy_Intel
Hello, @Sazirah:
It would help if you considered that this consultation is not related to an Intel Embedded platform supported through the channel you mentioned.
Please keep in mind this situation when this forum will be transferred.
